Old 01-06-2014, 02:27 PM   #1
Benson
Default 29 std coupe wood question
Does anyone know where these pieces go in Std coupe?
Thanks
These came in wood kit
Small blocks are 2 1/4 by3/4
Large are 6 1/2 by 1 3/4
Edited
Benson is offline   Reply With Quote
Old 01-06-2014, 02:34 PM   #2
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: 29 std coupe wood question
The ones on the left are body to frame mounting blocks, the right side ones may be part of the wood rail behind the seat on the body. The supplier might have just mixed up the parts, I received a 30 deluxe coupe domelight mount when I received the top wood kit for my 29 Special coupe. The 29 coupe never had a domelight.
Barry B./ Ma. is offline   Reply With Quote
Old 01-06-2014, 02:44 PM   #3
wrndln
I have a 28 special coupe I installed the top wood in. Standard and special coupes are similar, but of course, not quite the same. The piece of wood in your picture is like the curved ones in my kit and I am pretty sure they go between the rear wood over the back window around the curve of top as it goes to the back to the quarter window. I think it is used to tack the upholstery to when you install the curved upholstery covered rear corners. The small pieces were not in the special coupe kit, so I have no idea where they are used on you std coupe. I am attaching a picture of my original special coupe top wood. The area I believe the curve wood goes is in the upper right corner of the picture, which is a little different from a special coupe.
Rusty Nelson
Old 01-06-2014, 11:18 PM   #4
garyaodell
the sides of your top are in two pieces at the back of the door. there is a curved metal piece for both sides of the car that fits were the two top pieces come together, the two curved wood pieces fit inside the curve metal pieces so you can nail the two top metal pieces together.
garyaodell is offline   Reply With Quote
Old 01-07-2014, 03:57 PM   #5
Benson
That helps guys .. thanks much.
