Old 05-12-2010, 08:10 AM   #1
hotrod33
hotrod33's Avatar
Default Rebuilding a 1927 T starter.
I am new to model T's and I need to either rebuild or have a stater rebuilt for a 27 T. Who sells a kit with the brushes and parts... or who rebuilds them and about how much should it cost...... Thanks Bill
hotrod33 is offline   Reply With Quote
Old 05-12-2010, 09:37 AM   #2
Paul,WI
Paul,WI's Avatar
Default Re: Rebuilding a 1927 T starter.
You can get all the aprts you need from any of the parts dealers such as Langs, Bob's, or Mac's. I know Langs also offers rebuilt one's that you jsut send them your core as well. If you are good with this kind of work I would rebuild it myslef but if you don't feel comfortable or are unsure then either have a local electric motor shop look at it or buy the rebuilt one from Langs and send in your core.
Paul,WI is offline   Reply With Quote
Old 05-12-2010, 01:44 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I just installed the new unit made by a guy in Ohio with a 12 volt delco field coil and case. AWESUM starter !!!!!
I will dig up the info...this is the second one i have used wasnt expensive and makes a T start right up...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
