Old 11-29-2013, 11:22 PM   #1
19fifty4
Default New guy with question on water pump disassembly
Actually several questions…
1) How much force does it take to remove the fan assembly from the shaft? I’ve removed the cotter pin + castle nut and the fan assembly is holding fast. Am I missing something else or can I be less gentle with it.
2) In rebuilding / reassembly, are the packing, bearing felt, and bearing retainer, typically the only items needing replacement to address a leaky pump?
3) I currently have the exhaust manifold & head removed from the block repairing another issue. That work is complete and ready to be reassembled. Should I wait until I have the water pump ready to reinstall in the head before bolting up the head and exhaust? Or can I go ahead and get those items reassembled in the event I need to wait on water pump parts from the supplier.
I have a 29 Special Coupe that is mostly stock/original but it does have a 4 blade fan. I'm using Les Andrews Vol. 1 as my guide but would appreciate some feedback from you guys.
Many Thanks,
19fifty4 is offline   Reply With Quote
