Old 11-15-2013, 06:34 AM   #1
31 RPU
Default Steering column
What do you do when your notches on the quadrant are gone where your spark and throttle rods ride?
Also I need a worm gear if anyone has a good one?
Are the worm gears hard to get off the shaft? Should I use heat? And then there's getting one back on.......
31 RPU is offline   Reply With Quote
