11-14-2013, 12:30 PM | #1 |
ignition switch issues
I recently purchased a '31' coupe with only 1 key. Can't find a keyblank for the pop-out style switch because it is imported. Does anyone know if I can replace this switch without replacing the cable, as well?
11-14-2013, 12:45 PM | #2 |
Re: ignition switch issues
no. bob
11-14-2013, 01:13 PM | #3 |
I don't think you can do much with those old repro switches. You can get a new cable and modern switch from Bratton's or Snyder's for about $25. Or Dick Crabtree restores original popouts and can sell you one that's correct for your car. I think they're about $175. Pricey, but they're perfect.
Those old import popouts are notorious for shorting out anyway. I'd just hang it on the wall and get a replacement.
11-14-2013, 01:46 PM | #4 |
I had the same problem, took the key to a locksmith and he made me extra from blanks that he had
11-16-2013, 05:57 PM | #5 |
Sounds familar - last Year I bought a 31 coupe with a pop out switch with only one key - the key is flat on one side ( no groves) the local locksmith said " no problem - I can use a key with groves on that side " he made a key that works - he used a hillman key blank # IL8
Hope this helps |
11-16-2013, 09:56 PM | #6 |
