Old 11-06-2013, 02:30 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default 32-36 Distributor Nov special......
City: Indianapolis
State: Indiana
Price: $150
Another special for the Ford Barn from Bubbas Ignition....
This one is for the 32-1936 Helmet Distributor......36 can be two different models but this one is what i call the 3x3. Three holes to hold it to the engine and uses a three bolt ignition coil. Has the large strap contact points and the large tip rotor. Side terminal notches are on the back side of the distributor. Each is rebuilt, all parts polished , shined cleaned and painted. Then each unit is adjusted and machine tested to assure a long life on your car..
No side terminals or coil......
$150 complete with no shipping or core charge.
You can either paypal or call the shop to order the Nov Ford Barn helmet special .
317-487-9460
These are model 40B with 16 degrees of spark advance at 2500 rpm....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-10-2013, 11:33 AM   #2
BUBBAS IGNITION
Default Re: 32-36 Distributor Nov special......
Will add some 11a 24 degree helmets this week for $200.
[email protected]
Old 11-17-2013, 04:25 PM   #3
BUBBAS IGNITION
Two more weeks
[email protected]
