Old 11-05-2013, 03:48 PM   #1
mccsix
mccsix's Avatar
Default Engine ser no question
I have a 9 digit engine s/n preceded and followed by a star. No charts carry that large a #, so I'm guessing I'm dealing with a replacement engine, but did they make 4 cylinder engines thru 9 digits?
Gene
USN
mccsix is offline   Reply With Quote
Old 11-05-2013, 04:00 PM   #2
Bob C
Default Re: Engine ser no question
According to Vince's site probably the last Rouge built and numbered Model
A engine was 4872865 Jan 31, 1944. http://www.fordgarage.com/pages/ABenginenumbers.htm
Bob
Old 11-05-2013, 06:53 PM   #3
Charlie Stephens
You should not find a number over 5000000 as this was the start of the Model B engines. Ford stopped producing the Model A engines but left a few extra numbers for post production Model A engines. Any pictures?
Charlie Stephens
Old 11-05-2013, 08:02 PM   #4
mccsix
mccsix's Avatar
Eng s/n is
*276521667*
Gene
USN
Old 11-05-2013, 08:10 PM   #5
d.j. moordigian
d.j. moordigian's Avatar
Originally Posted by mccsix View Post
Eng s/n is
*276521667*
What is the "length" of the pad, in inches.
d.j. moordigian is offline   Reply With Quote
Old 11-05-2013, 08:11 PM   #6
d.j. moordigian
Eng s/n is
*276521667*
What is the "length" of the pad, in inches. Were the numbers are stamped.
Old 11-05-2013, 08:14 PM   #7
Bob C
I would say that not an original Ford stamping, there are no letters at the beginning.
Bob
Old 11-05-2013, 08:24 PM   #8
d.j. moordigian
Bob
Well done Bob....flat missed it!
Old 11-06-2013, 10:37 AM   #9
mccsix
mccsix's Avatar
For what it's worth the pad is 2 3/4" long. The pad looks to be original (very old) as well as the stampings. The edges are rounded and it looks like it was cast into the block. The head has a cast B on it.
So I'm not sure what Ive got here. Is there any way to determine, from an external view, whether this is an A or B engine?
Gene
USN
Old 11-06-2013, 11:44 AM   #10
1931 flamingo
1931 flamingo's Avatar
Probably an A with a B head. Does it have a fuel pump on the right side of the engine??
Paul in CT
Old 11-06-2013, 11:51 AM   #11
Bob C
If the head has the B cast into it it's a high compression Police head, very desirable .
Bob
Old 11-06-2013, 02:58 PM   #12
mccsix
mccsix's Avatar
No pump, so I'm guessing I've got a rebuilt A engine (by someone) with a good head. Did a compression ck on it last week got 82# in 3 cyls and 72# in no 3 hole. Currently going thru thru a stop leak cycle hoping for a quick cheap fix, and then I'll tap the oil pan and see what comes out. I was told the engine was rebuilt in the late 80's and the odometer was zeroed out, now has 1,674 miles on it and it runs strong.
Gene
USN
Old 11-06-2013, 05:16 PM   #13
old car guy
Could it be that some one ground the original number off and inserted there ss number which was. Common practice back in the day before identity thieving of our current life style. I personally have found the ss numbers on many old car parts and cars over the years as a form of ownership, especially if the owner had one stolen in their past. Today it would be very unwise to identify anything with your ss number.
old car guy
old car guy is offline   Reply With Quote
