Old 11-02-2013, 06:34 PM   #1
31 RPU
Default New pistons
Just got a set of new aluminum pistons for my engine rebuild from Brattons. These pistons don't have a slit at all in the skirt. How much clearance do you allow in the cylinder walls for these pistons? Is it the same as the pistons with the slit? There are no dumb questions...right?
Thanks
31 RPU is offline   Reply With Quote
Old 11-02-2013, 08:03 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: New pistons
Pistons with the slit can be fit a little tighter. Usually the new pistons have a clearance recommendation with them. Off hand I'd think about .0025 to .0035" would be OK, but wait for Dave or Herm to answer.
Old 11-06-2013, 09:01 PM   #3
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Correct: on the pistons they do recommend .002-.003" as i contacted them in Taiwan and a few weeks later i received a response.
J and M Machine is offline   Reply With Quote
Old 11-07-2013, 05:22 AM   #4
31 RPU
Ok, another question. The wrist pins can be pushed in with my thumb. It this ok? I thought they were supposed to be a tight fit?
Old 11-07-2013, 06:47 AM   #5
dave in australia
They will need c clips at each end. A full floating gudgeon should move in and out with finger pressure.
dave in australia is offline   Reply With Quote
Old 11-07-2013, 08:07 AM   #6
31 RPU
Not sure if I stated that correctly. The wrist pins slide into the piston easily. I thought they should be tight??
They have snap rings with the set. I have already fitted the connecting rod bushings to the wrist pin.
Old 11-07-2013, 08:09 AM   #7
J and M Machine
You stated it correctly.
They should be easy enough to slide through but not loose enough to fall out.
