Old 10-21-2013, 06:46 AM   #1
slackcat
slackcat's Avatar
Default New to the Barn with head questions
Hello! Cars aren't new to me but my '29 Coupe is. I found I was getting rad. fluid in the oil so I pulled the head and found the PO should have replaced his water neck, horribly pitted and letting fluid down both studs. Engine had rebuild but nuts not torqued enough, compromised head gasket, otherwise runs great.
I plan on getting a new water neck, high compression head (5.5), and related gaskets and studs from Snyders.
Questions:
1. Does Snyders carry long enough studs? I've read of high comp. heads
being thicker than stock.
2. They reccomend B gasket. Does it come in copper?
3. What is the proper torquing procedure and when is it safe to add
water?
4. Anything other particulars should I look for?
Lots of good info on this site, glad I'm here.
slackcat is offline   Reply With Quote
Old 10-21-2013, 12:35 PM   #2
SLPreston53
SLPreston53's Avatar
Default Re: New to the Barn with head questions
I have run their HC heads in two As with their recommended gasket and "stronger" studs with zero problems. The gasket is not copper, and while some disagree I have had no problems with the silicone lined gaskets. The proper torquing procedure is another point of debate (all the way to 55# in one lull or gradually sneaking up on it running through the sequence 3 or 4 times). But the pattern is start in the middle and circle toward the outside. I am sure someone will post an actual diagram of the sequence. You can add water as soon as torqued. I ran my A to get the head good and warm then waited until the next day to re-torque. Then, each time I take the A out, I re-torque the next day when the engine is stone cold until the nuts no longer need to be tightened (4 or 5 times).
SLPreston53 is offline   Reply With Quote
Old 10-21-2013, 02:18 PM   #3
CarlG
CarlG's Avatar
Brace yourself for about a million comments, each with it's own set of instructions.
Here's what Snyders has on their web site as far as the tightening sequence:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-21-2013, 08:54 PM   #4
slackcat
slackcat's Avatar
Heh, thanks for the input. I've read this forum for the last several months and just looking for some tips. I know better than to ask what engine oil to use and wether or not to use anti-freeze.
I have a nice driver and just wanting to get it back on the road. If I'm not here I'm on the HAMB.
Later.
Old 10-21-2013, 11:21 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Welcome to Model A's.
If you follow the recommendations of the vendor you should be OK.
Old 10-22-2013, 12:59 AM   #6
1930artdeco
1930artdeco's Avatar
On my 5.5 I went to 60# with the silicone gasket. No problems so far that I can see.
And welcome to the Barn.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-22-2013, 07:42 AM   #7
Dave in MN
Dave in MN's Avatar
'B' Head Gasket
Asbestos head gasket for the 32-34 4-cyl. Will also work on the model A. U.S.A.
Part NumberSpecificsPrice B-6051-C1928-34$25.50 / ea.
I rebuild about 24 engines each year and have tried numerous gaskets. Each has had its own problems. I ordered this head gasket from Snyder's about two months ago, tried it on an engine to be run on a dyno and found it to seal very well. It only required two sequences of re-torque to hold full torque of 55#. The silicone gaskets require 5-6 re-torques to hold. I have switched to using this gasket on HC heads from now on.
Good Day!
Dave in MN is offline   Reply With Quote
Old 10-22-2013, 07:48 AM   #8
slackcat
slackcat's Avatar
I'll make out my list and get my order coming.
It's sure a gas to drive an A, completely different from my other rides. My next goal is finding an A roadster.
Old 10-22-2013, 09:26 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Open cars are cool!
Most of the time too cool in Minnesota.
Old 10-23-2013, 07:22 AM   #10
slackcat
slackcat's Avatar
Originally Posted by Tom Wesenberg View Post
Open cars are cool!
I wouldn't let the cold stop me. Then again people think I was born in a barn.
Old 10-23-2013, 10:13 AM   #11
Jon
Jon's Avatar
I would suggest that if you are going to add antifreeze to wait and add it after the head is torqued the final time. That way if it does leak you won't get any antifreeze into the babbitt.
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 10-23-2013, 10:29 AM   #12
Phil
Phil's Avatar
Open cars are cool!
Tom, what is the machine by the building in the background? Looks interesting. Great Pheaton by the way, yours? Phil
Phil is offline   Reply With Quote
Old 10-23-2013, 11:10 AM   #13
Tom Wesenberg
Thanks, that's a vertical steam engine. Hemmings was here doing a photo shoot a couple years ago, and I'm at the Nowthen Threshing show grounds.
Old 10-24-2013, 01:06 AM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Slackat, if you're using the silicone lined gasket, this man's procedure is ALL you need to do
IF you use the thick squishy copper gasket, torque it again, immediately after warm up, & the next day, & several times thereafter, until the nuts no longer take ANY tightening. (And, PLEASE, don't back off the nuts when re-torqueing!) Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-24-2013, 07:33 AM   #15
zzlegend
zzlegend's Avatar
Does this help?
zzlegend is offline   Reply With Quote
Old 10-24-2013, 07:49 AM   #16
BILL WILLIAMSON
Originally Posted by zzlegend View Post
Does this help?
ZZ, Dog here, good clear pic, I culd draw if I had thumbs, & that's a good "RULE of THUMB" for most heads, if you don't have a pic. That's the same as Preston's sequence. Buster T.
Old 10-24-2013, 11:04 AM   #17
jacksonchuck
jacksonchuck's Avatar
My recent experience with the silicone coated Snyders gaskets on a newly rebuilt and surfaced engine and new 6.0 head is two failures leaving me stranded 250 miles from home. These occurred dispite numerous retorqings both hot and cold. They never seemed to stop needing to be retorqued. Both failed between #2 and #3 to cooling passage thus crapping up the oil with water and coolant with combustion products. The final reliable solution for me was a copper model B gasket (MACs), copper coat sprayed on both sides, 60# torque, and chrome moly studs. It took 3 retorquings to get it stable (all done cold). Checked it last week again after 2500 miles and is still right on the money. I dont doubt the silicone composite gasket would work for some folks but I no longer will use them.
jacksonchuck is offline   Reply With Quote
Old 10-25-2013, 11:24 AM   #18
slackcat
slackcat's Avatar
The parts came in yesterday and thanks for all the advice, I'll be referencing this thread when I reassemble.
Old 10-27-2013, 09:36 AM   #19
somethingspecial
somethingspecial's Avatar
slackcat welcome to the ford barn. Nice A by the way
somethingspecial is offline   Reply With Quote
Old 11-06-2013, 08:01 AM   #20
slackcat
slackcat's Avatar
Have the work done and followed installation to the letter. Haven't had the opportunity to go on any extended drives but can say it has more zip. Next I need to replace the coil wire, found it to be jerry rigged with a rusty screw as a contactor.
