Old 09-27-2013, 05:45 PM   #1
duna
Default front inner wheel bearing seals
i have a model A front axle with good hubs (in it's 3rd incarnation) that i plan to use under a boat trailer. i need to find some modern inner seals to replace the dust seals. has anyone done this before or have any ideas? i think that i can get a "bearing buddy" to fit on the outer hub. thanks, walt sonen
duna is offline   Reply With Quote
Old 09-27-2013, 09:21 PM   #2
Flathead
Flathead's Avatar
Default Re: front inner wheel bearing seals
I think you may be out of luck.
Flathead is offline   Reply With Quote
