#1 |
I was told { Or heard } That if you switch to Synthetic Motor oil or gear Lube that you should NEVER Switch back to the original oil's / gear Lube's.
Also what is " Synthetic " Oil products,is it regular oil's Refined in a different mannor or is it completely Man ( or women ) Made products combined & blended for a specific use? Those are my Questions / now my thoughts I know in my Large International Dump truck we use Synthetic Gear Lube The truck has Temp guages in the transmission & both rearends. I am amazed how cool the 3 units run,I don't think I have ever seen above 150* / 155* With our Flatheads being prone to running warm / Hot would the use of Syntheic motor oil Help to cool the motor by not adding to the heat build up? |
