Old 09-18-2013, 07:18 PM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Generator for the model A
Trying to set the amperage on the A using the gauge on the dash, and at a high idle I set the brush so the needle was between the 0 and 15 amp marks. When I checked the volts using a meter I was putting out 9 volts. When I had it set this way it always showed a charge on the meter except when I had the lights on. Now I used a volt meter and set the brush to put out 7.4 volts, but discharges big time when the lights are on. How should I be setting the genny.
Thanks, Tom
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
