#1 |
Is there a formula to determine how wide a rim should be
for a size tire ? ![]() Just a example ---If I make my rim 2" wider I can fit a 4" wider tire on it. AKA every inch wider I make the rim I can go two inches wider on the tire. ( THE ABOVE STATEMENT I DONT THINK IS TRUE ![]() { And for GOD sake don't try this at home ![]() ![]() |
#2 |
google Coker tire.
rich |
#3 |
In addition to Coker, other tire mfr. have similar info. It's often on a chart that not only shows rim width, but tire height, cross section width, and so on. Will look something like this:
Luck occurs when preparation and opportunity converge. |
#4 |
#5 |
a 4" rim max 6", a 10" rim max 12", a good rule of thumb but not gospel, each tire has a certain standard. If you have a 5" wide rim you have a limited option group of tires.
#6 |
If it comes up as a red X, then click on the X to open.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. ![]() |
#7 |
i've read that rim width and tread width should be within 1" of each other.
