#1 |
Tightened up drag link, tie rod ends, wheel bearings, steering box, and radius ball is tight in its socket. Still have wheel wobble at low speed. What's next?
#2 |
Well, only thing I can still think of is toe-in.. 1/16" inch toe in is needed, if it is toed out, you will get a wobble
![]() Hope this helps! |
#3 |
Jack up the car and spin the wheel to see if it runs true. If you are running original wires and hydraulic drums you need a spacer and without one you might have bent the wheel when you tightened it..
Charlie Stephens |
#4 |
