#1 |
Looking for the metal clip that holds the choke cable to the intake manifold on a 32 Model b engine. Thanks Pete.
#2 |
Pete,
Here is a picture of the clip you are looking for. Should be relatively easy to make. PM me if you need me to post some dimensions. You should put an ad in the wanted section. Be sure to include the Model A wanted section as this clip is not required when a B manifold is used in an A. Have you tried Renner's (734) 428-8424 and Baxter's (785) 842-9256? Charlie Stephens Last edited by Charlie Stephens; 09-16-2013 at 11:18 AM. |
#3 |
Thank You Charlie for the picture. Just what I am looking for.
#4 |
might try Roy at fordbolts.com seems the sort of thing he might have
Short URL: http://smu.gs/14g7eDW |
#5 |
clip - lock washer - plain head bolt 1932 thru 34 ford 4 cylinder new item made at renner's corner 1-734-428-8424 |
