08-25-2010, 11:56 AM | #1 |
Oil Capacity Question
I just changed the oil in my new-to-me 37 Ford. It only took 3 1/4 quarts and the dipstick indicated full. It is a 81A flathead, not a 21-stud engine. What should I do? The 37 original specs say 5 quarts. Has anyone had this experience??
Thanking you in advance................ |
08-25-2010, 12:03 PM | #2 | |
Re: Oil Capacity Question
08-25-2010, 01:49 PM | #3 |
the dip stick for the 81A is 11 23/32 from the stop coller to the FULL mark. It is 16 5/8" long. The same dip stick was used from 35-48. many of the guys feel it should take 4 qts some 5 qts. if you fill it too much it will leak out the rear or front of the crank. If you have the correct dip stick and outter tube which is about 8 21/64 long. I would fill it to the full mark and watch the level, checking often, especially after the first start.
08-25-2010, 01:56 PM | #4 |
Simply put in the correct amount of oil, where is reads on the stick mark it with a small file or grind a notch in the stick. Who know where your existing stick came from.
08-25-2010, 02:08 PM | #5 | |
08-25-2010, 03:25 PM | #6 |
Kerby |
08-25-2010, 07:32 PM | #7 |
I had a similar question a while ago. My 50 Ford has the stock dipstick and an oil filter. If I put in 4 quarts, it is right at the full mark. Putting in 5 quarts (due to the filter) makes it read high. I just put a mark on the stick where it reads with 5 quarts in it. I don't know if there where two different dipsticks for running a filter and not running a filter, but keeping it at the mark I put on has worked OK for 13 years.
08-25-2010, 08:52 PM | #8 |
I think mine is a truck pan,with large drain plug,and removable clutch cover.Is normal capacity for this one same as for a car pan?
