Old 09-11-2013, 01:10 PM   #1
Thor
Thor's Avatar
Default Factory 3x2 intake?
Hi Guys.
I have lurked here for a couple years and have finally gotten to the point where I will need to contribute. I recently purchased a '47 Super Deluxe Tudor that was an abandoned restoration project. It runs and drives - just need to put some of it back together.
I have been checking out sites like the Barn, the HAMB and various vendors to learn about flatheads and old Fords. In my travels I recently came across a fellow who has what he claims is an original factory 3x2 setup. He said they were originally used on police cars in California.
Did Ford make a factory 3x2 intake? Is this story even remotely true? I can't tell from looking at his photos if the intake is aluminum or cast iron. Any help clearing this up would be appreciated.
Thanks - I hope to hang around for a while and I am looking forward to tapping into the collective wisdom of the Barn.
Thor
Thor is offline   Reply With Quote
Old 09-11-2013, 01:27 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: Factory 3x2 intake?
From the looks of it, it could be a factory intake, stranger things have happened. However, it looks like it is for a late Flathead, 8BA, 8RT, 8CM, etc., not a 59A which was stock for your '47. Hopefully someone here will have the answer to yet another Ford Flathead mystery...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-11-2013, 01:50 PM   #3
FL&WVMIKE
FL&WVMIKE's Avatar
That is, surely, not a FORD part number, on it.
If that story is true, someone will know all about it. I doubt it, myself.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 09-11-2013, 02:02 PM   #4
Thor
Thor's Avatar
Guys,
Thanks for the response so far. I am only curious about this - no plans to put a multi-carb intake like this on my flathead...yet.
Thor
Old 09-11-2013, 02:07 PM   #5
42merc
42merc's Avatar
Looks like a welded up affair to me. Gotha & others used to sell the cast iron risers to weld to your single carb manifold.
The only factory backed multi-carbed intake for the flathead was the one used on '34-'35 Indy cars.
42merc is offline   Reply With Quote
Old 09-11-2013, 02:38 PM   #6
1963turnerjohn
1963turnerjohn's Avatar
42 Merc - the intake you refer to is the Hexagon twin carb intake - I have one on my 41 that my Grandpa fit to the car in 47 when he finished the hop up job on the car.
The Hexagon intake positioned the carbs 180 degree from the std positioning, which means you have to do a bit of adjustment on the throttle and chock linkages.
1963turnerjohn is offline   Reply With Quote
Old 09-11-2013, 02:57 PM   #7
42merc
42merc's Avatar
I know that.
CRS struck as I was typing, thanks for the memory bump.
Old 09-11-2013, 03:04 PM   #8
Bruce Lancaster
Gotha or similar, configured to function as a dual...they could be welded up level to be triples, but whoever did this wanted a low dual or he would have welded at that level to avoid linkage nightmares! You can see these things advertised in almost any issue of HRM for at least the first half of the 1950's.
Bruce Lancaster is offline   Reply With Quote
Old 09-11-2013, 03:38 PM   #9
ken ct
I assume you are refering to the race car,not whats in his pic is not a Hexagon manifold.Look closer the 2 stud holes are facing the front of the manifold which is correct positioning for a normal setup. Looks CI to me and definatly 49-53.As most after market multiple carb ones were Alum. This could have been made up by a good welder OMO. ken ct.
ken ct is offline   Reply With Quote
Old 09-11-2013, 03:43 PM   #10
ken ct
Hi John you got a bigger pic of your car in the avatar,looks fantastic wish the pic was bigger and more of them. ken ct.
Old 09-11-2013, 03:53 PM   #11
Jefscoupe
Jefscoupe's Avatar
That intake in the pics sure looks rusty enough to be iron. If it was a factory item it must be a "California" intake. At least on the tri 5 Chevys, anything that's out of the ordinary is labeled "California" one piece frame, "California" one piece bumpers, etc, etc...
Jefscoupe is offline   Reply With Quote
Old 09-11-2013, 04:09 PM   #12
1963turnerjohn
Hi Ken
Thanks for the note - the 41 is very special and I took a lot of effort to ensure she is put back to the hop up spec my Grandpa outfitted with after WWII from 46-47. The only thing that is different now is that the ride height is a bit higher then he ran - I am considering lowering 2-2.5" with new leaf springs - if this can drop her enough.
I added pics to my profile in an album - I hope you all enjoy them.
Best
John
Old 09-11-2013, 04:16 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Hi Ken
Best
John
That sucker sits GOOD...leave it alone! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-12-2013, 03:30 PM   #14
Vic Piano
Vic Piano's Avatar
1963turnerjohn, That car is sharp! I love the Lincoln steering wheel and the "spinner" hub caps, very cool!
Old 09-12-2013, 03:50 PM   #15
mfrk
I would think there would be a FORD script somewhere or at least a part #
mfrk is offline   Reply With Quote
Old 09-12-2013, 07:07 PM   #16
Bums F-1
Bums F-1's Avatar
I run a three carb manifold on my 50 F-1,I was at a show and did not know what class I was in. I ask the head of the show, he says original stock. I win first place, after picking up my award someone asks is three carbs a factory option,I say yes a police option. It may not seem fair but at a previous show the best Ford truck had a Chevy engine. So I guess I got even. But its not about the awards its having people say WOW when they look at your car or truck.
Bums F-1 is offline   Reply With Quote
Old 09-12-2013, 08:24 PM   #17
Ol' Ron
Ol' Ron's Avatar
You could buy these back in the 50's and 60's and braze them to your intake
Old 12-27-2013, 09:46 AM   #18
1963turnerjohn
Any updates on your '47?
Old 12-27-2013, 10:00 AM   #19
itsa52
itsa52's Avatar
Is it just me or does teh oil fill hole look oversize?? Why?
itsa52 is offline   Reply With Quote
Old 12-27-2013, 10:46 AM   #20
Charlie ny
John,
None finer...especially the provenance !!
Happy New Year
Charlie ny
Charlie ny is offline   Reply With Quote
