09-03-2013, 02:15 PM | #1 |
Wood Fillers
Would anyone know of a product being offered that will fill / repair wood and then be able to be drilled and accept a screw. One of my door handle attaching points needs some attention so that I can install new handles.
Thanks for your time. Cape Codder Last edited by Cape Codder; 09-03-2013 at 02:16 PM. Reason: missing word |
09-03-2013, 02:24 PM | #2 |
Re: Wood Fillers
I live in an 1887 Victorian house made of Redwood, and am constantly working on wood repair problems. Check with your local hardware store, as there are a number of easy fixes for wood problems, from two-part apoxies to a product put out by 'Bondo' fibreglass products. I also fill holes with a mixture of Elmer's Carpenter's Glue and finely ground wood powder from my table saw's 'trailings'. This works great.
09-03-2013, 02:44 PM | #3 |
Re: Wood Fillers
Alternatively, you can drill and plug the damaged screw-hole area with a fluted (straight or spiral) hardwood plug, readily available at hardware stores such as Ace. Use a good water resistant glue such as Tightbond II.
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. Last edited by Napa Skip; 09-03-2013 at 03:21 PM. Reason: Typo |
09-03-2013, 03:09 PM | #4 |
Re: Wood Fillers
as was posted earlier, drill out the bad part and plug with a hardwood dowl, you can use ask or birtch, any thing except pine, use the largest dowl to go in the biggest hole you can safely drill, drill repair hole just slightly smaller than the dowl so to get a real tight fit, use wood glue then drive dowl in, drill a piolet hole for the screw so as not to split the dowl, done right the repair is as strong as orignal
09-03-2013, 04:28 PM | #5 |
Re: Wood Fillers
I have used a wooden Q-tip and broken it off flush. This gives the new screw enough of a new bite to grip the old over sized hole. It is quick and easy and holds quite well.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
09-03-2013, 06:11 PM | #6 |
Re: Wood Fillers
09-03-2013, 06:17 PM | #7 |
Re: Wood Fillers
In the case I have the main hole for the door assembly handle has worn excessively and therefore there is nothing to put a dowel into. I wanted something that I could fill each side of the hole for the handle and then re-drill for a screw.
09-03-2013, 06:57 PM | #8 |
Registered User
Re: Wood Fillers
ive had great luck with using round toothpicks
coat them with glue and drive as many into the hole as you can,break them off flush it will be extremely strong experiment on another piece of wood to see what is feasible and how well you like it don't experiment on your door |
09-03-2013, 07:37 PM | #9 |
Re: Wood Fillers
Try some system 3 products from west coastUsed in wooden boat construction & repair
Good stuff |
09-03-2013, 09:28 PM | #10 | |
Re: Wood Fillers
Regular GORILLA Glue foams to fill voids & dries quite hard & tough, also. Bill W.
09-03-2013, 09:57 PM | #11 |
Re: Wood Fillers
mot's answer is what has been used by carpenters for decades. The toothpicks give meat and the glue not only bonds to the wood but it bonds tightly to the screw.
