Old 08-30-2013, 09:23 PM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Default 8BA block leaking water from exhaust port ?
Installed an 8BA engine with new rings,bearing and valve job.
Added water and a stream of water exiting thru the header on the passenger side.
Loosened the bolts on the header and the water is coming from the center port. Any help appreciated
dono50 is offline   Reply With Quote
