Old 08-29-2013, 05:07 AM   #1
MartyAndrew
MartyAndrew's Avatar
Default Shackle Holes Out of Round in Perches
Hi. The shackle holes are slightly oval in my 29's perches. Is there a fix? I think it would be tough to weld up deep in there. I know I could buy them but I'm also cheap...
See pics attached. Thanks for any help.
MartyAndrew is offline   Reply With Quote
Old 08-29-2013, 06:51 AM   #2
montanafordman
montanafordman's Avatar
Default Re: Shackle Holes Out of Round in Perches
Press in your new bushing and fill the small void that the shackle wore with JB weld. At least that's what I did. YMMV
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
Old 08-29-2013, 07:03 AM   #3
QGolden
QGolden's Avatar
I had one thst was frozen (rusted) to the shackle so bad, the bushing was spinning in the perch and egg shaped it. I took a used bushing, spun it in the lathe, used emery to take the OD down a couple thousands, wrapped it in plastic wrap, (Saran Wrap). Mixed up a batch of JB Weld and epoxied the bushing in. After it cured I pushed the bushing out and pulled out the wrap, then pressed in a new bushing. The repair is completely invisible after paint.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 08-29-2013, 08:48 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
That's what I would do also. I installed a couple repro shackles and had to make a small modification on the for a good fit. As I recall the repro casting was too thick in some area, so I had to grind it some.
Old 08-29-2013, 09:35 AM   #5
jimvette59
jimvette59's Avatar
First you need to remove the old bushings then push in your new bushing and fill void with JB weld as montanafordman had suggested.
jimvette59 is offline   Reply With Quote
Old 08-29-2013, 12:22 PM   #6
RockHillWill
RockHillWill's Avatar
I changed my mind on this one.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 08-29-2013, 01:18 PM   #7
Brentwood Bob
mig weld is preferred by me to jbweld, unless this goes to ebay after your repair.
Brentwood Bob is online now   Reply With Quote
Old 08-29-2013, 01:30 PM   #8
Tom Endy
Tom Endy's Avatar
Looking at the photos, there appears to be enough material there to adequately hold new shackle bushings in place. The oblong is caused by the shackle bolt wearing clear through the bushing into the perch. A local shop here in Southern California does have a repair. They insert a bronze rod into the perch that is the same diameter as the shackle bushing. They then fill the void around it with weld. Apparently the weld does not adhere to the bronze and they simple remove it. I have had several axle housings repaired by them.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-29-2013, 08:55 PM   #9
MartyAndrew
Wow, thanks everyone. I was strongly leaning toward using JB weld exactly as a few of you have described but wasn't sure it would work. Glad to hear your success stories, and to find yet another use for good ol JB Weld! Thanks a ton. That's one thing I'll be doing this weekend. Wife and daughter are on a girl trip up north with my mom, and son is at an amusement park with a friend. I am free to work on the Model A for a few days!
Marty
Old 08-29-2013, 09:19 PM   #10
Tom Wesenberg
I'm not sure if JB Weld comes in slow and fast setting, but when 2 parts epoxy glues come in both, I prefer the slow set. It gives you more time to work and I think it's stronger. It takes overnight to set up.
Old 08-29-2013, 10:01 PM   #11
SeaSlugs
SeaSlugs's Avatar
yea the 2 parter can usually dribble down deep in it while the putty is like modeling clay but equally strong i feel. ALOT easier to work with in situations where you dont want it to run haha
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-29-2013, 10:22 PM   #12
Roadster62
Roadster62's Avatar
Do you believe there is any reason to index the seam in the bushing? Do you Loctite the bushings? Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 08-29-2013, 10:32 PM   #13
Tom Wesenberg
I index the seam to be 90* from the thrust side. I've never used locktite, because the bushing were already hard to drive in place.
Old 08-29-2013, 10:33 PM   #14
QGolden
QGolden's Avatar
The bushing should be a light press fit, no need to loctite it as the shackle, if greased proper and not tightened to much, rotates inside the bushing. It is just a piece of hard steel to provide a bearing surface to prevent the shackle from wearing through the perch. As for index, I don't think there is a seam to index, at least mine did not have any.
Old 08-30-2013, 11:07 AM   #15
Russ/40
Russ/40's Avatar
Interesting thread. A few years ago I proposed the JB solution and was shot down for it. I took a totally different solution. The bushing perches are forged steel, so they do weld easily. I did it differently in what I think is the best way to go. Remove the old bushing. Find some bar stock the same size as the OD of the new bushing. With an oxy-acetylene torch heat the worn side of the perch to red. When you get the perch hot enough, insert the bar stock into the perch, and with a hammer, forge the perch down to the bar stock to create a new concentric bore. Remove the bar stock before the perch cools. Now you can weld the perch from the outside easily to a shape you can dress down with a grinder of file to look correct. The resulting shrinkage as the perch cools will give you the interference fit you want for the new bushing. Much easier than trying to weld inside a hole, and the end result leaves no question as to durability.
Russ/40 is offline   Reply With Quote
Old 08-30-2013, 04:10 PM   #16
john in illinois
john in illinois's Avatar
That is the traditional way to fix it for sure. Would save rear axle perches instead of welding on replacements. I would never have thought of that.
John
john in illinois is offline   Reply With Quote
Old 08-30-2013, 04:50 PM   #17
tbirdtbird
you can insert a carbon rod or ceramic rod of the proper diameter in the hole, then crank up your welder and weld all the way thru to the rod, and then build up the weld a little on the outside. in this way you do not change the overall dimensionality of the perch. The weld on the outside can then be contoured with a die grinder, and on the inside with a die grinder or a file. The inside will be very very close to what you want because of the rod. This is really easy to do if the perch is out and you can have it upside down to have gravity help you. If the perch remains in the car you have to be a good welder to make this work. Trigger the MIG so you don't melt the steel out. Carbon or ceramic rod is the standard fare for a welder. Brass or bronze could work but some of it might melt, I have never tried it. If you triggered to be able to control the heat and it would prolly work. Next time I have an oval hole i will try it.
This trick works also if you are fabbing and have a hole in a plate that needs to be made smaller....put the carbon etc rod in the middle on the floor and fill the remaining space with weld.
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-30-2013, 06:48 PM   #18
Doug in NJ
Doug in NJ's Avatar
The carbon rod + MIG trick worked very well for me when I repaired a rear perch:
http://31ford.dougbraun.com/suspension_work/IMG_5320
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 08-30-2013, 08:05 PM   #19
Steve Plucker
But Will...we still would like to hear your expertise and thoughts on this one!
Pluck
Old 08-30-2013, 08:15 PM   #20
Bill Underwood
Carbon rod can be had from welding supply or McMaster Carr. Often called gouging rod.Can't remember if it is 3/4 or 7/8. Put in the hole and weld up the voids, mig or tig or gas
If rod is stuck, drive it out and there you have it. Insert new bushings
Swap Meet - The Ford Barn
https://www.fordbarn.com/forum/forumdisplay.php?f=6
Bill Underwood is offline   Reply With Quote
