Old 08-20-2013, 06:21 PM   #1
pebo va
Default Halogen 6V tail lights
Do halogen 6V tail light bulbs burn too hot for a '49-50 SW tail light and do they draw too much power causing other problems. I would like to increase the brightness of stop, blinkers, and running lights. I painted the inside gloss white but no real help.
pebo va is offline   Reply With Quote
Old 08-20-2013, 07:10 PM   #2
TJ
TJ's Avatar
Default Re: Halogen 6V tail lights
Look for some 6 volt LED's. You'll be a lot happier. They don't get hot and are brighter.
TJ is online now   Reply With Quote
Old 08-20-2013, 07:41 PM   #3
OLD...BILL
OLD...BILL's Avatar
Try " superbrightsleds.com " thay make LEDs in twist lock base, fir you show box. ...OLD...BILL
OLD...BILL is offline   Reply With Quote
Old 08-20-2013, 08:42 PM   #4
JT FORD
JT FORD's Avatar
I have two halogen bulbs I would like to sell. The wiring would not handle them!
JT FORD is offline   Reply With Quote
Old 08-20-2013, 10:52 PM   #5
Old Henry
Old Henry's Avatar
I tried halogen, I tried LED, and neither compared to the super brights from Sacramento Vintage Ford here: http://www.vintageford.com/part_sear...3-6sb&Category
Their bulbs do not draw the current halogens do and they shine all directions unlike the LEDs. They look and fit just like the original bulbs but are just a whole lot brighter. And they're cheap compared to either of the others. I'll never use anything else.
See photos to demonstrate the differences between all bulbs in my 47 here: https://www.fordbarn.com/forum/showthread.php?t=67558
Old 08-21-2013, 12:53 PM   #6
cabrioletgalaxie
I use 6V halogens in my headlights, parking lights and tail/brake lites on my Model A Ford. Never had an issue with heating and never burned out a bulb. These bulbs are used with my OEM generator, not an alternator.
I will check out Sacr. Ford though to see what they have.
cabrioletgalaxie is offline   Reply With Quote
Old 08-21-2013, 01:02 PM   #7
mralternator
Send a message via Yahoo to mralternator
A 6 volt Alternator supplies more than enough to keep all new lights very bright, and No fluctuation that is sometimes found with other devices Just saying
mralternator is offline   Reply With Quote
Old 08-21-2013, 01:42 PM   #8
Old Henry
Old Henry's Avatar
When I put in halogens with stock wiring they worked but the brake lights lit slowly and not much brighter than the tail lights. I then installed 9 ga. wire and they worked fine but quickly burned out my brake light switch. I then added a relay but the bulbs soon died. That's when I tried LEDs that were too directional and didn't even light up my whole lens and was looking for something else when I was put onto the super brights from Sacramento Vintage Ford that have worked great - bright as halogens but a lot cheaper, last longer, and don't draw as much juice.
