Old 08-14-2013, 12:06 AM   #1
my4dv8
Default Next Oversize pistons for 3 5/16
I have done a search but just checking to ask if there is a 3 5/16 x 4 inch stroke oversize available ,like 25thou over ?? It would sure save an old overbore block.
my4dv8 is offline   Reply With Quote
Old 08-14-2013, 12:21 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Next Oversize pistons for 3 5/16
How about sleeves if you can not find the size you need?
Old 08-14-2013, 12:51 AM   #3
my4dv8
Yes I did suggest that to the owner , as it is really only one bore hole that needs help, but he wants to replace all. The current pistons are Ross 3 5/16.
Old 08-14-2013, 01:31 AM   #4
Brian
Brian's Avatar
Ross will manufacture to any size, but 3 5/16 plus .030" at least should be in stock. Email them....
Brian is offline   Reply With Quote
Old 08-14-2013, 10:02 AM   #5
GOSFAST
GOSFAST's Avatar
The first numbers to establish would be if the rings are available for a certain bore size.
Assuming you have a 3.312" bore with some "minor" wear there is a ring set out there for a 3.317" finished bore. It is a "metric" set (1.5, 1.5, 4.0) but we use these all the time. Once you've established this size is available you go back and order the pistons to "match", so to speak.
Ross, for instance, would build the pistons to that ring configuration and you'd be good to go. The "finished" pistons would be in the area of 3.313" (nominal). The "stocking" pistons for a finished 3.312" bore would be around 3.308".
We always try to "save" these hard to find blocks with "minimum" boring & honing whenever possible.
(Add) Make certain to use a block plate on the final honing! Especially on these Flatheads. They are strong but they are also "thin" by todays standards.
Thanks, Gary in N.Y.
P.S. We just built 2 Flathead pistons sets, Ross, for inventory, using a 3.228" finished bore size. The "moly" rings, metrics, are available from Speed-Pro as a stock ring size for a certain 4 cyl application. We use 2 sets for each package! These sets would be +.040" over for the OEM 3.188" bore.
GOSFAST is offline   Reply With Quote
Old 08-14-2013, 12:48 PM   #6
Ross6860
Great info...
Ross6860 is offline   Reply With Quote
Old 08-14-2013, 02:13 PM   #7
Ol' Ron
Ol' Ron's Avatar
I just bought a set of 3 5/16 +.020" from Egge thay come with metric rings from a Volvo. They also make a 3 5/16 + .5-" over. Great piston very light.
Old 08-14-2013, 02:28 PM   #8
my4dv8
Thanks , knew we rely on the barners to come through .
Old 08-14-2013, 07:49 PM   #9
Kahuna
Kahuna's Avatar
My engine has +.015 oversize from Egge. 3.330"
Kahuna is offline   Reply With Quote
Old 08-14-2013, 09:31 PM   #10
38 coupe
38 coupe's Avatar
I have heard that some of the Egge pistons hit the head unless you cut down the crown. Does anyone know about this?
Old 08-14-2013, 09:48 PM   #11
flatjack9
flatjack9's Avatar
I have not had that problem.
Old 08-14-2013, 10:10 PM   #12
Ol' Ron
Ol' Ron's Avatar
I've been using Egge pistons for over 20 years and never had that problem. I usually have to mill the heads to get the 40-50 thow piston to head Clarence.That may not make any sens to you but that improves turbulence an economy.
Old 08-15-2013, 02:05 AM   #13
Lawrie
Lawrie's Avatar
Egge will make a custom size piston,the did for my LB block,.065.
Lawrie
Lawrie is offline   Reply With Quote
Old 08-15-2013, 02:50 AM   #14
my4dv8
Yes that makes a bunch of sense, more turbulence means better burn = more power and economy.
often EGGE piston can be a little tall anyhow.
