Old 07-31-2013, 04:20 PM   #1
Mad Mac
Default Grease on brake shoes
Recently I found my rear RHS brakes were not working at all, even after tightening up the adjustment with a spanner. When I removed the brake drum I found lots of grease on the lining and on the interior contacted surface of the drum.
I conclude that either I have been greasing the rear brakes too much (2 or 3 squirts every 500 miles) or I need new seals or both. Anyway what I want to know is this: Do I have to re-line the shoes or is there some product that will get the grease off sufficiently to get the brakes working again? I have some "Brakekleen" here, but my friend says it will only achieve a temporary fix and after a while more grease will seep out of the linings. He says I will have to renew the linings, but as they are not worn there is no other reason to renew them. What do you guys think?
Mad Mac is offline   Reply With Quote
