Old 07-23-2013, 08:50 PM   #1
Maclab58
Maclab58's Avatar
Default High compression head
I have recently purchased a 31 Victoria which the previous owner who was a broker didn't know if the engine had been rebuilt. I recently changed the pan gasket and was happy to find new Babbitts, cam,lifters, valves and pistons. Unfortunately the crank isn't balanced but it runs great and will do 50 mph pretty easy. What would adding a 5.5 compression head to the mix gain me? I would like a little more take off power, not really worried about top end speed. 50-55 mph is fast enough.
Thanks!
Maclab58 is offline   Reply With Quote
Old 07-23-2013, 09:16 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: High compression head
Do a compression check. Maybe it already has a 5.5 head. If not, the higher compression head should give you the extra power you want.
Old 07-24-2013, 02:31 PM   #3
Maclab58
Maclab58's Avatar
What should I look for on the compression check?
Old 07-24-2013, 02:33 PM   #4
Bob C
High compression
Old 07-24-2013, 03:05 PM   #5
Jason in TX
Jason in TX's Avatar
75-85 psi...
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
