Old 07-19-2013, 08:33 PM   #1
Steve Plucker
Default Off/On Switch between Battery and Starter
How many of you have an off/on switch between the battery and the starter?
Pluck
Old 07-19-2013, 08:42 PM   #2
Tony S,Fl.
Tony S,Fl.'s Avatar
Default Re: Off/On Switch between Battery and Starter
Count me for having one on the ground side. Tony
Tony S,Fl. is offline   Reply With Quote
Old 07-19-2013, 08:48 PM   #3
Jack S.
While at an electrical seminar during the week long national meet at Lexington, KY., one member reported a serious fire that he witnessed caused by some form of problem of wiring at the starter negative (6v.) point on the top of the starter.
Maybe your question ties to this exposure? It sounded pretty serious.
The seminar was extremely informative and well worth attendance. The club
surely put a lot of time and serious effort into the week long event. They deserve credit for pulling this event together.
Jack S. is offline   Reply With Quote
Old 07-19-2013, 08:57 PM   #4
clocey
clocey's Avatar
I have one between the battery and starter
1930 Model A Fordor Murray Body
clocey is offline   Reply With Quote
Old 07-19-2013, 09:00 PM   #5
Mitch//pa
i put them in between the battery and frame, and mount the switch on the crossmember under the seat,,, positive ground
Old 07-19-2013, 09:21 PM   #6
BudP
BudP's Avatar
Ground cable to switch, ground cable out of switch to frame, switch mounted on seat riser, just behind lower left leg.
BudP is offline   Reply With Quote
Old 07-19-2013, 09:25 PM   #7
mystic122468
mystic122468's Avatar
i've got one, positive side with a removable key..
Jim
mystic122468 is offline   Reply With Quote
Old 07-19-2013, 09:28 PM   #8
Charles Coe
Charles Coe's Avatar
I have one between battery & starter.
Charles Coe is offline   Reply With Quote
Old 07-19-2013, 09:41 PM   #9
stallerl
stallerl's Avatar
I have one on my '29 Tudor that I mounted on the cross member just under the seat. It's on the positive ground cable.
stallerl is offline   Reply With Quote
Old 07-19-2013, 09:53 PM   #10
Pinstripe
Yes and I use it always. Do not want a fried car.
Pinstripe is offline   Reply With Quote
Old 07-19-2013, 09:58 PM   #11
QGolden
QGolden's Avatar
Yup, I install them on every build I do.
I use these. Easy to unscrew, the Green cap switch disconnects the power and I can put it in my pocket.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 07-19-2013, 10:03 PM   #12
Bruce Adams
Bruce Adams's Avatar
I have the heavy duty brass cut-off switch above the starter button so I can flick it off or on with my foot any time. Yes, it leaves the path between the battery post and the switch unprotected, but the ease of use outweighs the possibility of a short on that distance.
Bruce Adams is offline   Reply With Quote
Old 07-19-2013, 10:22 PM   #13
Elcastor
Elcastor's Avatar
Ok, I will be the odd ball. No, I never have had one in the last 43 years.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 07-19-2013, 10:32 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Do you think it would be easier if you started a thread with a poll asking yes or no?
Old 07-20-2013, 01:42 AM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
So if they're SO important, why didn't pre-solid state cars have them? If your battery to starter cable is routed properly & secured where necessary, & you have a main feed fuse or a circuit breaker, what's the chance of a disastrous short? I feel that a cut off switch is just something else to possibly fail. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-20-2013, 03:29 AM   #16
Mike V. Florida
Careful Bill, A's came with neither fuses or cut out switches.
Old 07-20-2013, 03:49 AM   #17
Allanw
Allanw's Avatar
Same - ours is between the 2 Tudor seats..... although ours in a 6V Negative ground
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 07-20-2013, 04:04 AM   #18
Barney
Barney's Avatar
Hi,
I have this between the Battery and the Starter.
What is the reason of your survey?
Barney
Barney is offline   Reply With Quote
Old 07-20-2013, 06:31 AM   #19
Ed Saniewski
Ed Saniewski's Avatar
All three of my cars have the switch between the battery and the starter mounted next to the engine mount. This way I remember to check my oil when I turn on the battery.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 07-20-2013, 06:44 AM   #20
Aok
Aok's Avatar
No do not have one ; however I have replaced all my wiring.
Aok is offline   Reply With Quote
