Old 07-18-2013, 09:47 PM   #1
Fred K-OR
Fred K-OR's Avatar
Default Muffler shield under the floor boards???
Have a question about these shields that you put over the muffler to shield the floor boards from getting hot. The question is: Do they do any good???
We took about a 75 mile trip in the huckster last weekend. Had some energy bars in a sack on the floor boards by my wife's feet. Well we ended up with melted energy when we tried to use the bars. So do these things help to keep the floor boards cooler or are they just a sales push by the vendors.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 07-18-2013, 10:08 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Muffler shield under the floor boards???
i would imagine they would work to some degree. lots of modern cars have heat shields on the catalytic converter and sometimes on the muffler. i mean if ford gm dodge etc could save a nickle by not putting them on they would.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-18-2013, 10:27 PM   #3
SLPreston53
SLPreston53's Avatar
We had one of the less expensive ones on our Tudor and didn't notice any difference. The high-dollar ones may be better.
SLPreston53 is offline   Reply With Quote
Old 07-18-2013, 10:32 PM   #4
tbirdtbird
i tried one a yr ago from a reputable supplier and it was a piece of junk....too thin and vibrated like crazy, i threw it away
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-18-2013, 10:35 PM   #5
SeaSlugs
SeaSlugs's Avatar
aparently i was wrong haha. speaking of melted food DONT put a package of fudge in a cooler in front of the floor vent then drive 2.5 hrs to a relatives house for Christmas with the heater on...end up with a saran wrap sack of blob fudge...refrigerate it and ate it - tasted the same...
Old 07-18-2013, 11:11 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
With the temps we've had the past few days, the energy bars would have melted even if they were in a cooler. My cooler top blew off the other day while on a return trip from a small town celebration. I found an old metal cooler at a local garage sale today to replace it.
I would think any heat shield would be a benefit. One of our club members works sheet metal in his HVAC shop, so some of the guys made their own shields.
Old 07-18-2013, 11:16 PM   #7
Jordan
Jordan's Avatar
I've found insulation to be way more effective than the heat shield.
Cowtown A's
Jordan is offline   Reply With Quote
Old 07-19-2013, 12:06 AM   #8
700rpm
700rpm's Avatar
My engine splash pans work very well to reduce heat from the engine compartment and muffler. Insulation would do doubt help even more.
Fred, I sent you an email.
Ray Horton, Portland, OR
Old 07-19-2013, 12:19 AM   #9
Rock Hornbuckle
Rock Hornbuckle's Avatar
The 'heat sheild' is a layman's term for a 'radiant energy shield'. They do stop radiant heat. To prove this, you need to use a piece of aluminum foil. Hold your hand approximately 6 inches fron a burner on your kitchen stove. Then, hold the aluminum foil between your hand and the burner. you will feel the difference. No guess work, no old wives tale, just pure science.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 07-19-2013, 04:42 AM   #10
Pat Martone
Pat Martone's Avatar
See the link provided below. I have used this muffler shield from Aries Muffler, and found it to be well made and it reduces the heat penetration into the passenger cabin; the link includes test data:
http://www.amuffler.com/content/hotfooting.htm
Pat Martone is offline   Reply With Quote
Old 07-19-2013, 09:24 AM   #11
tbirdtbird
that may or may not be the one i got from a reputable A supplier, but it looks similar. It was made from sheet metal that was way too thin and flimsy and vibrated like crazy. I threw it in the trash.
I went with floorboard insulation with good results
'31 180A
Old 07-19-2013, 10:07 AM   #12
TinCup
TinCup's Avatar
There are two shields out there for purchase. One is just a metal shield and the other is some type of insulation sandwiched between two pieces of metal. The latter works better IMO on the cars I have seen. I have the plain metal type and on longer drives it reaches critical mass as to what it can deflect.
TinCup is offline   Reply With Quote
Old 07-19-2013, 10:08 AM   #13
Duffy1
You can make your own sheild . Do a search for instructions . A little sheet metal and two large radiator type clamps .
Duffy1 is offline   Reply With Quote
Old 07-19-2013, 10:12 AM   #14
steve s
steve s's Avatar
The good one is made by Leslie Pam in California and costs about $100 after shipping. I have one and believe that it helps--also, supported by actual test data. I have only heard bad things about the cheaper one sold by the parts suppliers. Perhaps it is news to some that even the reputable suppliers occasionally sell junk. Leslie advertises in the mags; calls it Kool-feet or some such.
Steve
steve s is offline   Reply With Quote
Old 07-19-2013, 12:22 PM   #15
Pat Martone
The shield that I mentioned previously with the link to Aries Muffler, is in fact, the Dr Leslie Pam heat shield which I purchased directly from him. It is well made, with two layers of galvanized steel with a sandwiched layer of some kind of heat resistant cloth in between the steel outer layers. It also comes with well-made U brackets and nuts/lockwashers.
Old 07-19-2013, 01:43 PM   #16
Rainmaker Ron
Rainmaker Ron's Avatar
Fred, The common shield will let you know when you are going 35 MPH, it rattles about then until the brackets fatigue and break. I have a solution that works for me. Wrap the muffler with a piece of corrugated barn siding and secure with large hose clamps. That's it, you are done! The air washes down the 5/8 corrugations and carries the heat out the back. It helps to position the siding about 3 inches ahead of the muffler to catch the air.
Rainmaker Ron
Rainmaker Ron is offline   Reply With Quote
Old 07-19-2013, 03:04 PM   #17
Jason in TX
Jason in TX's Avatar
It helps. Paired with insulation, it keeps you much cooler. I made my own from an old street sign I got at a junk store. Here are some instructions..
Cut to roughly this shape..
Get these hose clamps at Home Depot in the Air Condictioning duct work isle if I remember.
Bend your sheet of metal
Made these little clamps...
assemble
Installed
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 07-19-2013, 03:21 PM   #18
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I made one similar to Jason's. However, I mounted it by bolting it on top of the bottom frame rail using the forward bolt of the brake cross shaft bracket and the hole in the frame about 14 inches forward of the brake cross shaft. I also insulated the under side and the top side of the floor board. It works great. No complaints from the passenger..
Dick M is offline   Reply With Quote
Old 07-19-2013, 03:33 PM   #19
roccaas
roccaas's Avatar
I've got the insulation and sheet metal sandwich. Works great until you cut the floorboard to install the transmission dipstick and metal cover!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 07-19-2013, 04:11 PM   #20
700rpm
700rpm's Avatar
I tried a shield and it was snug up against the brake shaft. I jiggered things around until I got some space between, but the rattle drove me crazy, so I took the whole outfit off. As I said up above, the engine pans seem to do a lot for cooling.
