Old 07-11-2013, 07:13 PM   #1
bhiland
Default engine pans?
Who's running them and do they help. I know some people that do and some don't so wanted to get others thoughts.
bhiland is offline   Reply With Quote
Old 07-11-2013, 07:23 PM   #2
Mitch//pa
Default Re: engine pans?
yes they help and i always run them on my cars.
use the search feature on the top of the page in the black area and there will be plenty to read about them
Old 07-11-2013, 07:27 PM   #3
glenn in camino
glenn in camino's Avatar
I have them on my 5 running Model As. They look great, they help keep the engine clean, and they probably help the cooling system work better. They also make your Model A complete.
glenn in camino is offline   Reply With Quote
Old 07-11-2013, 07:30 PM   #4
bhiland
Thanks. I dont have any but know a huh that will give me some. Just wondering what to do.
Old 07-11-2013, 07:31 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I also run engine pans and like them. They help cooling, help keep the engine compartment cleaner and add an extra engine to frame ground. I've read that they increase cooling by 15%.
Old 07-11-2013, 07:43 PM   #6
johnsor
A very good investment for the reasons posted above.
johnsor is offline   Reply With Quote
Old 07-11-2013, 07:47 PM   #7
Aok
Aok's Avatar
Have engines pans no reason that I can think of not to install them
Aok is offline   Reply With Quote
Old 07-11-2013, 08:29 PM   #8
Patrick L.
Patrick L.'s Avatar
Can't answer your question. I have always used them, they're supposed to be there.
Old 07-11-2013, 09:41 PM   #9
Pat Martone
Pat Martone's Avatar
I have heard that you cannot use the engine pans if you're using rear Float-A-Motor mounts, but I do not know if this is true.
(I use engines and original style engine mounts.)
Pat Martone is offline   Reply With Quote
Old 07-11-2013, 09:43 PM   #10
SeaSlugs
SeaSlugs's Avatar
speakin of pans: did AA's use them too?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-11-2013, 09:45 PM   #11
Brian SATX
Brian SATX's Avatar
I have float a motors and pans.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 07-11-2013, 09:49 PM   #12
Pinstripe
Pans are as much a part of the car as the engine is a part of the car.
Pinstripe is offline   Reply With Quote
Old 07-11-2013, 09:49 PM   #13
Ron in Quincy
Ron in Quincy's Avatar
After the A, Ford continued to use engine pans into v8 years. It helps cooling by directing more air to the rear of the engine instead of dumping the air out the louvers on the hood sides.
Ron
Ron in Quincy is offline   Reply With Quote
Old 07-12-2013, 12:53 AM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Yo, Pat, Minerva had FAM's front & rear & side pans!
FAM's DON'T make the motor flop around, or drift forward, or rock & roll sideways!!! They just do a MARVELOUS job of insulating engine roar & vibrations from getting into the chassis & body! I'd put them on Vermin, but I'm tired & will drive him "Bone Stock"!
There's SO much mis-information & old tales about FAM's, but if you want a smooth driver, they're a MUST & very similar to Henry's '32 Model B mounting system.
And yes, Minerva was MAFCA's car of the day once! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-12-2013, 01:05 AM   #15
BILL WILLIAMSON
Ron
I personally, "feel" that with side pans there is less air going out the bottom, causing MORE air out the louvers & helping to keep the manifolds & carb cooler. No, I don't have a thermal heat gun to prove it! (I'M POOR!) LOL Bill W.
Old 07-12-2013, 02:09 AM   #16
RHD
RHD's Avatar
Wouldn't run without them.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 07-12-2013, 02:32 AM   #17
Jordan
Jordan's Avatar
I've had them on before. But they were always such a pain to install. I noticed no difference in cooling- but then again I have a good radiator. They do, however, keep the engine cleaner.
Cowtown A's
Jordan is offline   Reply With Quote
Old 07-12-2013, 06:48 AM   #18
1crosscut
1crosscut's Avatar
Sure did.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-12-2013, 07:59 AM   #19
Phil
Phil's Avatar
Run the pans. All the reasons above + a friend had a rock jump up and put a hole in his sediment bowl. Could have worse than just loosing a couple gallons of high dollar gas.
Phil is offline   Reply With Quote
Old 07-12-2013, 08:43 AM   #20
Farrell In Vancouver
Farrell In Vancouver's Avatar
I have a set on a chassis of a 30-31 short wheel base AA. They will find their way on to my new truck to be sure.
Farrell In Vancouver is offline   Reply With Quote
