Old 07-05-2013, 01:02 PM   #1
duffer
duffer's Avatar
Default brake and clutch pedal question
While i was under the car looking around i noticed this on loop on the brake pedal shaft with nothing connected to it. Is there supposed to be something on this or was it put together wrong? Sees to work fine the way it is .Just looks funny.Here is a picture from the top and bottom.
duffer is offline   Reply With Quote
Old 07-05-2013, 01:07 PM   #2
Rock Hornbuckle
Rock Hornbuckle's Avatar
Default Re: brake and clutch pedal question
It looks like somone welded that on. Maybe (I'm guessing) for an additional brake return spring?
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 07-05-2013, 01:19 PM   #3
MAG
MAG's Avatar
I have a brake pedal with the same modification. It was used to operate the master cylinder for hydraulic brakes.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
