Old 06-12-2013, 04:55 PM   #1
SP_51-F1
SP_51-F1's Avatar
Default 3-speed w/overdrive fuse
What size fuse should be used on a '50 3-speed w/ overdrive. Was running a 30amp, but it blew and I'm not sure if it's because it was the wrong amperage.
If 30amps is correct, quick ideas as to what could be causing it to pull to many amps?
I'm diagnosing this over the phone, Mom's on her way to Tahoe, so I can't just break out the multimeter and start chasing wires.
SP_51-F1 is offline   Reply With Quote
Old 06-12-2013, 05:06 PM   #2
trainguy
trainguy's Avatar
Default Re: 3-speed w/overdrive fuse
30 amps is about right,the coil in the OD solonoid is the big current draw.
trainguy is offline   Reply With Quote
Old 06-12-2013, 05:28 PM   #3
Mike51Merc
Mike51Merc's Avatar
30 Amp fuse. Don't put a bigger one in. Find out why it blew.
Mike51Merc is offline   Reply With Quote
Old 06-12-2013, 05:28 PM   #4
charles in east texas
charles in east texas's Avatar
SP, tell Joyce to pull out the overdrive handle and drive it like a standard shift. Then find the trouble when she gets to Tahoe. Charles
charles in east texas is offline   Reply With Quote
Old 06-12-2013, 05:34 PM   #5
SP_51-F1
SP_51-F1's Avatar
Thanks Charles, might just be what we have to do.
They have been fighting heat problems all the way, not just my Mom, and I was hoping she could use the OD to keep things a little cooler.
They are replacing the fuse and going to see how long it will go this time.
Old 06-12-2013, 06:49 PM   #6
Planojc
Planojc's Avatar
Since they are in Albuquerque, I would use the OD as much as possible until they get to high country. I heard the ign. timing was off which would account for the overheating problem.
Planojc is offline   Reply With Quote
Old 06-12-2013, 06:50 PM   #7
Planojc
Planojc's Avatar
I have found many of the OD relays with loose connections at the input tab as well as the fuse holder. They are held in place by a brass rivet and over time the connection is minimized due to corrosion. On all my relays I clean the area and using a good flux and a big iron, solder all rivet connections, including the ones under the cover. Loose connections will blow a fuse.
Old 06-12-2013, 07:03 PM   #8
joe 1950
joe 1950's Avatar
they have a 30 amp circuit breaker your can get from all most any parts store napa for sure has them, this is only putting a bandage on the problem, does it blow when it goes into o.d. or after a while of driving if no bare wires and no rivets loose its very poss.solinoid shorting out
joe 1950 is offline   Reply With Quote
Old 06-12-2013, 08:13 PM   #9
SP_51-F1
SP_51-F1's Avatar
Thanks everyone, but she's going to leave it a EFV8 members garage and take it easy in a rental for the rest of the tour.
I think the timing was the heating problem too. Apparently however, even with a good fuse it was not kicking in to overdrive. I hope that means the solenoid is bad and nothing is wrong internally. Or the wire connection to it shorted it. I guess we'll see.
Old 06-12-2013, 09:11 PM   #10
Sorry to hear that. Driving in standard shift might make the car run cooler rather than in overdrive. Charles
Old 06-12-2013, 10:08 PM   #11
Ross F-1
Ross F-1's Avatar
It could be the solenoid pull-in coil is remaining on, instead of switching to the hold-in coil. The pull-in coil draws a lot more. I have a spare here in the Albuquerque area, if the EFV8 club member wants to contact me (I am familiar with some of the members).
Ross F-1 is offline   Reply With Quote
Old 06-13-2013, 10:41 AM   #12
SP_51-F1
SP_51-F1's Avatar
Thank you Ross, I'll let you know.
Old 06-13-2013, 02:47 PM   #13
rotorwrench
rotorwrench's Avatar
A 30-amp fuse is a pretty big one. It usually takes a direct short to ground or a bad internal short in the solenoid to cause that.
Old 06-13-2013, 03:37 PM   #14
Planojc
Planojc's Avatar
Repairing and calibrating electronic test equipment for 30 plus years, many times a piece of equipment would come in with a blown fuse. Most times there was a reason for it to blow, but many times you could just replace the fuse and for unknown reasons it would never blow again.
Old 06-13-2013, 04:33 PM   #15
I agree with you John. That has happened to my overdrives before.
Chas
Old 06-13-2013, 04:59 PM   #16
trainguy
trainguy's Avatar
The fuse on my 51 drove me crazy!! It didn't blo it would just stop working.I ended up soldering tyhe fuse clip, as mentioned above and cleaning the oxidation,no problems since.Your problem [as stated above] most likly is a short in the wiring or a malfunction of the sol holding circuit.The holding coil is controled by a set of points inside the sol. and can be cleaned by removing the cover.Phil
Old 06-13-2013, 05:18 PM   #17
35fordtn
35fordtn's Avatar
My 50 had a overdrive relay go bad and they are hard to find.. I have several friends who also had this problem
35fordtn is offline   Reply With Quote
Old 06-13-2013, 06:14 PM   #18
rotorwrench
The engine compartment wasn't the best choice for fuse placement in an open environment like that. Perhaps some silicon grease would keep the corrosion at bay.
Old 06-13-2013, 06:49 PM   #19
donald1950
also be sure that the wire from the relay to the solonoid is 10 ga or so. i had alot of fuse blowing and i discovered that some one had a 14 ga wire to the solonoid and the wire was getting hot from the current flow and causing alot more resistance.. replaced it with 10 ga and had no more problems..... don
donald1950 is offline   Reply With Quote
Old 06-13-2013, 06:56 PM   #20
52merc
52merc's Avatar
the relays and solenoids are available new in either 6volt or 12
trev,, whats life "TOUGH" whats tough ' LIFE"
52merc is offline   Reply With Quote
