Old 06-09-2013, 04:14 PM   #1
sanborn
sanborn's Avatar
Default Crankshaft "Clean Out" plugs
Any suggestions to remove the clean out plugs in a 4" Mercury crank?
sanborn is offline   Reply With Quote
Old 06-09-2013, 04:30 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: Crankshaft "Clean Out" plugs
This is how I do it. Drill and tap a 3/8 course thread in the plug. Use a slide hammer with a 3/8 bolt in the end and screw it into the plug and clunk it out. On the Ford crank with the smaller plugs just drill and tap a 5/6 thread in the plug. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 06-09-2013, 04:30 PM   #3
oldford2
oldford2's Avatar
Walt Dupont recently gave us a "seminar" on these cleanout plugs. He drills and taps them then uses a slide puller to remove the plug. The Ford plugs are smaller than the Mercury plug. Then, after cleaning the oil channels drive in new Merc plugs. Maybe Walt will chime in to a source..
John
oldford2 is offline   Reply With Quote
Old 06-09-2013, 04:31 PM   #4
VeryTangled
VeryTangled's Avatar
Obviously these replies are coming in fast, but...
Sanborn, I'm not the expert here, but I was witness to Walt Dupont giving a V8 oiling seminar that I captured and put on youtube. Google search for 'Walt Dupont Oiling' and you'll find three videos. The end of the second and the beginning of the third cover some of your question. Again I'm not the crank/engine guy, but I hope this helps.
Thread here, with links to the videos, might help some also, but it spirals into a discussion mentioning (gasp) SBC's.
https://www.fordbarn.com/forum/showth...=dupont+oiling
-VT/Jeff
VeryTangled is offline   Reply With Quote
Old 06-09-2013, 06:00 PM   #5
Pete
Cheap insurance, tap the holes and install hex drive pipe plugs on
assembly, ESPECIALLY if you are going to use a high volume oil pump.
Old 06-09-2013, 07:01 PM   #6
Russ/40
Russ/40's Avatar
Pete, I've always wondered about any balance issues using the pipe plugs. Any insight you'd like to share about that?
Russ/40 is offline   Reply With Quote
Old 06-09-2013, 07:31 PM   #7
Pete
The pipe plugs are a couple of grams heavier.
Balancing is the last thing you do so it doesn't matter what you use.
You make up the bob weights to what you use.
Old 06-09-2013, 08:25 PM   #8
GOSFAST
GOSFAST's Avatar
The amount is negligible, it will have no effect on the unit!
The plugs can be removed simply by "punching" an awl hole through the plugs and use a "dent-puller" with a screw mounted in the end! Works every time, takes about 10 minutes to remove all four.
We use 3/8"-NPT x. 360" deep, 8-grams, and I believe that's less than the OEM Merc pressed ones?
Thanks, Gary in N.Y.
P.S. The Merc cranks with the larger plugs are ready to tap, not necessary to drill first! The Fords with the smaller plugs we drill & tap.
GOSFAST is offline   Reply With Quote
Old 06-09-2013, 09:11 PM   #9
Russ/40
Russ/40's Avatar
Aluminum or Iron plugs?
Old 06-09-2013, 11:25 PM   #10
denson1932
denson1932's Avatar
And thread sealer like #2 gooey stuff?
denson1932 is offline   Reply With Quote
Old 06-10-2013, 05:59 AM   #11
JWL
Sanborn, use a 14mm sparkplug tap to cut some threads into the ID of the crankshaft plugs and screw a slide hammer into those threads. No drilling, no muss, no fuss. For several years I even reused the removed plugs but now get new Dorman's.
Are you going to be running your dragster at Bowling Green this week? If so I'll try to stop by and say "howdy".
JWL is offline   Reply With Quote
Old 06-10-2013, 07:21 AM   #12
Walt Dupont--Me.
JWL. That's a good idea, never thought of that. Of course that just with the Merc 5/8 plugs. You've probably come up with an idea for the Ford 3/8 plugs. Walt
Old 06-10-2013, 08:32 AM   #13
GOSFAST
GOSFAST's Avatar
The aluminum plugs weigh around 3 grams (nominal), it's just not cost effective from a business standpoint due to the prices.
Other than that fact there's no real reason you couldn't use them however.
P.S. The aluminum plugs average 2.00/ea give or take, the steel's are just pennies!
Old 06-10-2013, 08:34 AM   #14
sanborn
sanborn's Avatar
Yes, we will be at the "Hot Rod Reunion" this weekend. By all means, please stop by and say hello. And that same offer is for everyone at the Ford Barn!
Also, I bought a set of Wilson & Woods heads for my engine. I am impressed with some features. I would like to show them to you.
Old 06-11-2013, 05:34 AM   #15
JWL
I always use aluminum pipe plugs in the cranks that I change to "screw-in". To think that $8 worth of pipe plugs will make a $1700 crank assembly unobtainable calls into question the thought processes.
The SCAT cranks can be converted to 1/2" pipe, aluminum plugs, to help reduce throw weight.
Old 06-12-2013, 02:58 PM   #16
sanborn
sanborn's Avatar
I got the plugs out-----thanks for the info. The crank was totally packed with dried "goo". I really don't see how any oil could get through the crank to the rod bearings.
Thanks for the advice!
Old 10-08-2015, 05:51 PM   #17
Bluebell
Do I understand correctly that screw in plugs were used in 8BA cranks? (2 hole throw, Ford)
If so are they NPT ? (1/8th)
Who sells steel Allen type plugs?
Bluebell is offline   Reply With Quote
Old 10-08-2015, 07:45 PM   #18
TomT/Williamsburg
TomT/Williamsburg's Avatar
My one 4" cranks that I done had to tapped for the screw in plugs. Your local auto supply or hardware store will have the plugs once you know what they are tapped to ...
TomT/Williamsburg is offline   Reply With Quote
