#1 |
first time disassembling a model a engine// removing valves I now realize you must knock down the valve guide before valve can exit head according to les Andrews red book. I have keepers out now.
is a special tool required or can I improvise an other way? fredski |
#2 |
You need a special tool. They are readily available from parts suppliers, and relatively cheap compared to trying improvise.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#3 | |
![]() Quote:
If you don't mind risking bending a valve or breaking a punch, a small diameter punch (1/8") can reach in under the valve head and contact the top of the valve guide and a tap with a hammer can get the guide started. This is how I have done it on several occasions. Go slow, go easy and you can ease them all out. But you're on your own for damaging the valves or chipping the guides (they're HARD). Wear safety glasses. Joe K
Shudda kept the horse. |
#4 |
I like this one;
#5 |
The one Mike shows is the better tool.
#6 |
The curved tools loose too much impact force in the curves, and will not remove a stuck guide. |
