05-10-2013, 06:55 PM | #1 |
Nickel plated screws
I recently had some screws nickel plated. They were done by electroless plating. The screws came back with a dull finish. Is this the way electroless plating is? I thought the nickel plated screws should be bright finished. Maybe there is a way to polish them. The screws are for mounting the radiator splash apron on a 1928 car. If anyone knows anything about electroless nickel plating, please post a response.
Rusty Nelson |
05-10-2013, 07:51 PM | #2 |
Re: Nickel plated screws
The plated screws will only be as shiney as the metal underneath. If they were not polished they will be dull.
05-11-2013, 12:49 AM | #3 |
polish them with polishing compound using your bench grinder with a cloth wheel, they will shine up, careful tho, those suckers like to launch them selfs across the room and hide in very strange places
05-11-2013, 03:17 AM | #4 |
Depending on the thickness of the plating, you should be able to polish the nickel in the same way as you would polish any other plated object, remembering not to polish through the plating. Objects can be polished before plating, and will produce a better post plating finish. We used to use electroless nickel where an even thickness of plating was the highest priority, as the parts could not be re-worked after plating to make dimensions correct. |
