Old 05-01-2013, 12:27 PM   #1
firetique57
firetique57's Avatar
Default King pin question
I asked this over on the HAMB site with no replies so I thought I'd ask here.
I'm rebuilding a 30/31 Model A frame. Just got the frame back from sand blasting and I'm ready to start re-assembly. I'm thinking of going with juice brakes instead of the mechanical. Should I change the king pins to do away with the cup for the brake actuator and if so which king pins will work with a stock Model A axle and spindles? I've read the other threads here about mechanical vs hydraulic brakes and I'm not debating pros or cons just interested in the king pin issue at the moment. Thanks!
Andy
firetique57 is offline   Reply With Quote
Old 05-01-2013, 01:10 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: King pin question
Are you going to adapt the hyd backing plates to the A spindles?? If so I would keep the A king pins. JMO
Paul in CT
Old 05-01-2013, 02:38 PM   #3
Rowdy
Basicly you can use any 28-48 kingpins. Most use the 37-41 kingkins for the clean look, others use whatever they can get the cheapest. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
