Old 04-29-2013, 02:31 PM   #1
kwisor
kwisor's Avatar
Default painting radiator
hello all
can i paint my rad with out making any problems i do not want to start over heating if so what do i use
thank you
kevin
1930 model a tudor
1923 model t roadster p/u
kwisor is offline   Reply With Quote
Old 04-29-2013, 02:37 PM   #2
sethkestenbaum
sethkestenbaum's Avatar
Default Re: painting radiator
It is my understanding that there is a special radiator paint. Regular paint should NOT be used. the radiator paint should only lightly be sprayed onto the radiator and DOES reduce the cooling a little. This is information from my discussion with the owner of Natick Radiators in Natick Mass. I have not yet painted mine and am not an expert. I just tend to over-research things.
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 04-29-2013, 03:02 PM   #3
BrianM
BrianM's Avatar
Eastwood sells rattlecans of Radiator Black paints, both Gloss & Satin. I think the satin looks better on an A. $14.99 a can. Go lightly.
BrianM is offline   Reply With Quote
Old 04-29-2013, 03:03 PM   #4
whirnot
whirnot's Avatar
I just had my radiator in the shop for a leak, it took them two days to boil the paint off. Do not paint it! The issue is the are tiny bubbles created when the paint is subjected to the heat of the engine. This creates an air space, and cooling ability is reduced. They do use a special radiator paint. If it were me and I wanted to paint it, I would take it to a shop, have it cleaned and painted. Good maintenace.
I don't think it would be that expensive, they charged my $60 to clean, repair and paint mine.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-29-2013, 03:09 PM   #5
Arlen
Arlen's Avatar
Here in TX where it can be 108 in the summer easy, we paint ours. I like a semi gloss sold at Ace Hardware. Never had any heating problems. Maybe they sell special radiator paint but I'm willing to be your local radiator shop doesn't use it.
DMAFC
Arlen is offline   Reply With Quote
Old 04-29-2013, 05:46 PM   #6
Rock Hornbuckle
Rock Hornbuckle's Avatar
As an Energy Engineer, I have done many heat loss/gain calculations, and paint is a consideration in the calcs. I can tell you that thermodynamically paint slows heat flow. That means, it reduces the efficiency of your radiator. But, it's your choice.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 04-29-2013, 06:09 PM   #7
larrys40
I have a great radiator shop here in west County St. Louis do the "A" radiators... and I always have them leave it unpainted..... so I can see the repairs and condition, and see for myself before I paint & install. I have used some of the black BBQ grill paints, semigloss and other flats before.... carefull not to get too heavy but to coat it.... I have never had a problem with any paint causing an overheating problem.... In my experience..... If there is a cooling problem... if you think think the paint is the problem.. it is really probably something else... radiator poor flow, clogged tubes, engine has scale and debris .. etc
I would suggest using a infared temperature meter to check the heat of the radiator top to bottom, left to right to identify how it is really cooling and flowing... of course if you hit a cool spot with a low reading you'll know you're not getting flow in that area.
I think most of the standard spray can paints of your choice will do the job... your probably just better off with one of the thinner varieties. Flat black BBQ or otherwise. Give it good overall coverage..and you should be fine.
Good luck
Larry S.
larrys40 is offline   Reply With Quote
Old 04-29-2013, 07:28 PM   #8
glenn in camino
glenn in camino's Avatar
I've been using Krylon semi flat black for years with no problems.
glenn in camino is offline   Reply With Quote
Old 04-29-2013, 07:42 PM   #9
BrianM
BrianM's Avatar
Here's Eastwood's special radiator paint:
http://www.eastwood.com/ew-radiator-...sol-12-oz.html
They also have it in satin finish as P/N: 10340Z
Works fine on my radiator, but plan on a black trigger finger!
Old 04-29-2013, 07:49 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I've also used semi gloss black in a spray can and had no problems. Spray from both left and right as you face the radiator, and you'll get a light coat of paint on the visible part, but it really doesn't coat the fins very far back. It'll look good and cool fine, if the radiator isn't plugged up.
Old 04-29-2013, 08:24 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Painting radiators is mainly to prevent external corrosion of the fins & tubes. To "freshen" up my core, I've dipped a soft paintbrush in watery, liguid, stoveblack and passed it across the fins. It'll just wipe off the shell, if you "slip"! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-29-2013, 08:28 PM   #12
kwisor
kwisor's Avatar
hello
thank you for the replays i think i will use eastwwod rad pant
kevin
1930 model a tudor
Old 04-29-2013, 08:34 PM   #13
Mitch//pa
I paint mine cause it looks slick
