#1 |
This is probably not the proper venue for this question; if not I'm sure I'll get suggestions on where to go...
#2 |
a BUDDY PUT A fE 390 into a a 56 ford back in 1962,thing was bad fast at the time. He said it want in fairly EZ.
#3 |
FE's are your better choice. I think you may need to turn one around, but they use the same motor mounts.
I bought a 351 for my '57. I then found a 292 on craigslist cheaper than the cost of messing with that windsor. |
#4 |
I'm very partial to y blocks, but one caveat. Before you go to an FE, make sure it is a T-85, not a T-86, and that it is the R-11, not the R-10 o/d. I know the HD units weren't in the birds in 55, but many were changed out. The 86 will work, but don't drop the clutch with good traction. Don't ask how I know.
#5 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
I'm curious. How much does the crate engine you're looking at cost?
#6 |
#7 |
I may be a little partial but NOTHING looks better or sounds better than a Y-Block in a mid-fifties Ford.
![]() Like Miker says, check the trans and OD before putting a lot of power to it. |
#8 |
A small block, 302 or 351 would be a good choice. 302's go in with stock mounts but the trans adaption can be a problem as it will be with a FE. FE's go in pretty easy (but probably not as easy as a 302), but its very tight and you might have to go with heavier springs.
#9 | |
![]() Quote:
![]() An FE would be an option, but I'd be hoping for something that gets a bit better gas mileage, something FE's aren't known for. This is all in the kicking around stage at the moment and I probably wouldn't do anything until winter unless the 292 decides to give up the ghost. |
#10 | |
![]() Quote:
Performance Unlimited has a 347 ci 350 hp stroker for $6400 (turnkey) Summit has a 306/340 hp long block for $3699 and a 347/400 hp long block for $3995 Stock rebuilds: PS Engines has a 302 long block for $1439, or a 351 long block for $1539 Of course the ancillary costs have to be figgered in; the elusive, possibly custom transmission adapter, mods to the shift linkage and driveshaft and whatever else may be involved. And if going the long block route figure in the cost of an intake and carb, etc, etc. The problem with rebuilding the 292 is most of the machine shops in my area seem less than enthusiastic about messing with an antique. That may mean it would be a slack time project that would be shoved to the back burner when more bread and butter type work comes through the door. Decisions, decisions ![]() |
#11 |
#12 |
Their down right now, due to a server problem, but when it's up, go over to the y-blocks-forever site. You won't get any encouragement for an engine change, but there has to be someone there in your area who can recommend a machine shop. For the money and work your looking at for a change, you might also go to John Mummert's site, and look at some of the performance parts. The guy near Seattle who did my machine work did the old motors because doing valve jobs on ricers got boring. You walked in, and there was a nail head, early hemi, tri power Pontiac. Got to be someone like that near you. Ask the guys running other vintage motors if that's what it comes to.
Nice motor, y-blockhead. |
#13 |
Dobie,
Try Charlie's Machine in Murfreesboro. He's done flatheads, y-blocks and any other Ford engines. Does good work. Did a couple of sets of heads for me (y-block and FE). 615-494-0076 I don't own any interest in his shop and get nothing for this advertisement. Just throwing out an option for saving a y-block. Also, Shacklett in Nashville is very good with vintage engines. Did some work for my grandson, but I don't have his number handy. There are plenty of folks in middle Tennessee who can do it, but unfortunately there are a few who will say they can but can't. Beware of those. |
#14 |
If you want to keep the original trans a FE with a 58 to 64 bellhousing should work since with flipping the motor mounts it will bolt in,if you decide to get rid of the 292 I have been thinking about trying to find a 55 292 to put in my 55 sunliner. If you want to go with a windsor a 64 and earlier 289 should bolt to your original trans.
#15 |
i put a 289 in a 57 and used the 57 trans,.just drilled out the bell.
#16 |
After much consultation and soul searching I have decided to keep the Y in the Merc. She made it nearly 60 years with it; she's prolly good for another 60 (at which time I'll be, um, a ripe old age). One of the guys on Y-blocks forever (who's also a neighbor, it turns out) suggested a machinist not too far distant he's used with good results. So this week I'll pull the valve covers after work and check for anything obvious. I wonder if he'd be willing to come over and help get those insanely heavy heads off (hint, hint)?
Thanks to everyone for their advice. This is a great forum! |
#17 |
I am glad you decided to keep the Y,I put a 351-w in my 55 sunliner and not very happy with it. The nimrod who built the motor stuck in the wrong cam so I am going to build a 292 for it soon,it seemed like the original 272 had more low end torque then the 351 so its going back to a torquey Y block.
#18 |
