Old 04-19-2013, 08:53 PM   #1
KMeredith87
KMeredith87's Avatar
Default Engine noise/clicking
I've been trying to figure out an engine noise I have and am getting no where with it. The noise is random and sporadic and comes and goes. It sounds like a clicking noise in the valve area. It does not seem to matter if the engine is warm or cold because it happens at both times. When the clicking starts if I rev the engine it tends to click once more slightly louder and then stop but not always. I did loosen the distributor lock screw to see if possible the shaft was binding but seems to be little to no change, maybe slightly quieter but that's all. Any ideas?
KMeredith87 is offline   Reply With Quote
Old 04-19-2013, 09:07 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Engine noise/clicking
Worn cam plunger and/or spring allowing the cam to walk.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
