04-11-2013, 06:09 PM | #1 |
53 merc head questions
I have a 53 merc motor. I'm buying a set of 8cm heads for it. I can also get a set of eab heads for it. Should I buy extra set? 100 a pair. Do they have diff compression? Should I use fresh head bolts? Best gasket? Any other advice is appreciated. Thank you.
04-11-2013, 06:20 PM | #2 |
Re: 53 merc head questions
In my opinion buy the EAB heads instead of the 8CM heads. Higher compression ratio.
04-11-2013, 06:29 PM | #3 | |
Neal |
04-11-2013, 06:32 PM | #4 | |
Neal |
04-11-2013, 07:11 PM | #5 |
50 for heads. 50 to ship...watt a gonna do.
04-11-2013, 07:15 PM | #6 |
04-11-2013, 08:10 PM | #7 |
The EAB heads, as stated, are higher compression which yields more fuel economy and performance. The Merc engines - 8CM - used a larger combustion chamber because they had greater displacement. It depends on what you want. I have a 276" 8ba with EAB heads and am very pleased with it. There is a significant difference in the combustion chamber size of the EAB and 8CM heads.
Henry |
04-11-2013, 08:15 PM | #8 |
8CM's are good boat anchors unless you are building a blower engine.
04-11-2013, 08:18 PM | #9 |
04-11-2013, 08:43 PM | #10 |
Use a new gasket and clean the bolts with a wire brush, you can oil the treads and torque them to 45 ft/lbd for 3 heat cycles. DO NOT over torque!!!
04-11-2013, 09:39 PM | #11 |
I had both when I rebuilt my engine. I chose the EAB and they have been great. I had them "cleaned up" when I had the block done, just to make sure they were flat.
04-11-2013, 10:17 PM | #12 |
The difference is approx. a 7% increase in compression.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
04-12-2013, 07:55 AM | #13 |
Is 7% worth it? Better w ba or rt? How much clearance do I need for eab heads?
04-12-2013, 12:54 PM | #14 |
04-13-2013, 11:20 PM | #15 |
Damn look at that. Asked a dumb question. Paid attention to good folks and learned something. Thanks for everything guys.
04-14-2013, 11:11 AM | #16 |
For what it is worth: Not sure what you are going to do with the 53' Merc engine, but if you are looking for a paint color for the heads and block: Dupli-Color Engine Enamel DE1618 Detroit Diesel Alpine Green. You can get it at most auto parts stores in a rattle can. The picture of the thermostat housing is with the original paint on one half and the Dupli-Color on the other half. The other picture was when I got a set of the EAC heads and decided to clean up the block in the car. This was before I bought a new block and built a new engine....big crack in the block.
04-14-2013, 04:57 PM | #17 |
never a dumb question....always a learning experience....Mike
