Old 04-09-2013, 11:44 AM   #1
Texxracer22
Default 29 Model A running funny
I just finished a complete restore of my 29 Model A Truck. Had the carbs done by a guy who really knew his stuff. It will start, idol and sounds great until i get about 5 minutes of running then is starts to bog down and back fire. I will be trying all the basics but any ideas where to start?
Texxracer22 is offline   Reply With Quote
Old 04-09-2013, 11:52 AM   #2
KMeredith87
KMeredith87's Avatar
Default Re: 29 Model A running funny
Out of curiosity as it sat for any period of time with fuel in the tank? Beautiful truck by the way.
KMeredith87 is offline   Reply With Quote
Old 04-09-2013, 11:58 AM   #3
Patrick L.
Patrick L.'s Avatar
Had the carbs done by a guy who really knew his stuff. end quote.
Just what does that mean ? A little info would be nice.
Old 04-09-2013, 11:59 AM   #4
Wife Unhappy
Loosen Gas cap and go for another ride.
Wife Unhappy is offline   Reply With Quote
Old 04-09-2013, 12:13 PM   #5
ford3
it may not be the carb, maybe points, coil or condensor, those problems sound like electrical, either one of them getting hot and breaking down
ford3 is offline   Reply With Quote
Old 04-09-2013, 12:22 PM   #6
700rpm
700rpm's Avatar
How many carbs have you got on it?
Ray Horton, Portland, OR
Old 04-09-2013, 12:25 PM   #7
gweilbaker
gweilbaker's Avatar
If you have more than the common updraft carb you maybe starving for gas. Maybe a need for a fuel pump if you're running any kind of downdraft carb.
gweilbaker is offline   Reply With Quote
Old 04-09-2013, 01:49 PM   #8
Duffy1
Ditto post #4 ; Could be the Gas Cap not venting . Mine did the same thing .
Duffy1 is offline   Reply With Quote
Old 04-09-2013, 02:06 PM   #9
kelley's restoration
kelley's restoration's Avatar
i was told once by a friend who worked on a lot of cars of different types "if you think its carb its probably ignition"
so if the gas cap trick doesnt work (i has for me in the past) then check your condensor
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 04-09-2013, 02:08 PM   #10
robw
robw's Avatar
Make sure you have a good fuel flow. Disconnect from the carb and let it flow into a Jar for a few minutes. You could have trash blocking the on/off valve, or trash in the sediment bowl.
robw is offline   Reply With Quote
Old 04-09-2013, 04:43 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
What carb (s) are you running?
The original carbs have a brass scren in the top half and it sometimes stays stuck in place when the large nut is removed.
Old 04-09-2013, 05:07 PM   #12
Hicktick
Hicktick's Avatar
Could a critter have nested in your muffler ?????
Join a local club and get some help .There should be plenty in Texas .
Hicktick is offline   Reply With Quote
Old 04-09-2013, 05:17 PM   #13
31Tudor
31Tudor's Avatar
Could also maybe be a bad coil. If they are going bad, you will start off just fine, but when it heats up after a little bit of runnning, it will have those symptoms as well.
31Tudor is offline   Reply With Quote
Old 04-09-2013, 07:19 PM   #14
Texxracer22
Good thinking. I haven't tried yet but I just remembered I am using a radiator cap
Old 04-09-2013, 07:29 PM   #15
christian
christian's Avatar
well, radiator caps arent vented.....
1931 Slant Windshield fordor
christian is offline   Reply With Quote
Old 04-09-2013, 08:12 PM   #16
Tom Wesenberg
A dirty trick to pull on someone is to switch the gas and radiator caps when they aren't looking.
Old 04-09-2013, 09:07 PM   #17
Texxracer22
I had noticed the cap issue but failed to realize what would happen. I'll try that then the ignition stuff. I leave for a week in the am but I'll post the results later. Thanks for all the info
