Old 04-06-2013, 05:14 PM   #1
jkcrosson
jkcrosson's Avatar
Default Speedometer Question
My speedometer works about 1/3 of the time. It will work most of the time when i first start driving the car but stops shortly after. Do you think this is a speedometer or a cable problem.
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 04-06-2013, 05:29 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Speedometer Question
You could unscrew the housing from the speedometer, jack one wheel and run the car while watching and holding the cable to make sure it turns. You can also remove the speedometer drive from the driveshaft and give it a look.
Old 04-06-2013, 07:05 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I would do just what Patrick suggested, and my first guess would be a worn driven gear on the driveshaft. I haven't replaced one, but by removing the small end cap you should be able to slide out the shaft and replace the driven gear. My 28 was worn, but I had a spare good complete 10-37 ready to bolt on, so that was an easy fix for me.
Old 04-06-2013, 07:08 PM   #4
jkcrosson
jkcrosson's Avatar
Thanks guys. I will try check it out next week and let you know.
Jamie Crosson
1929 Tudor
