Old 04-05-2013, 11:42 PM   #1
Mike/Nebraska
Default running a #94 on my banger
Well I finally got an intake so I'm going to put my #94 on with a header, I know some of you run downdrafts on your bangers so I was woondering how much pressure do I need in an electric fuel pump? And...where would I buy such a thing, Also where should I start on jets. My motor hasa counterbalanced crank, a B cam, a Snyders 5.5 head and a lightened flywheel. I also have an over drive.
Mike/Nebraska is offline   Reply With Quote
Old 04-05-2013, 11:57 PM   #2
Rowdy
Default Re: running a #94 on my banger
3 Psi regulator between pump and carb. I will look to see if I still have my notes from Spence's Splinterbox. Seems the one he tried from Vintage Speed left a lot to be desired. Rod
Rowdy is offline   Reply With Quote
Old 04-06-2013, 12:10 AM   #3
ken ct
Hey Rod,i did some carb work for him a few yrs ago but dont have any receipes by now any more.For a Woody wag. i think same deal if i remember 4 banger with a 94. ken ct.
ken ct is offline   Reply With Quote
Old 04-06-2013, 12:17 AM   #4
Rowdy
Yes, he ran it in the GR in 2005, 2006 and 2007. He ran t a 97 on flatlands and had a 94 set back to run in the mountains if I remember right. The NOS throttle plate for the 94 he sent you was one I sent to him. It was a pleasure being part of getting it ready. Afew parts came from my shop along with getting daily updates and input questions. Going to have to dig hard for my notes. Rod
Old 04-06-2013, 12:19 AM   #5
Mike/Nebraska
Thanks rod...do you know where I can buy a 6v elecric fuel pump? do I run the pump and then use a fuel regulator too. I may even try and trade it for a rebult Sttromberg #48
Old 04-06-2013, 12:24 AM   #6
Rowdy
Seperate regulator. 6v pumps are not real hard to find. What is hard to find is a decdent adjustable regulator. Be sure to put an inline gauge on it that reads 1-10 lbs. If I did not need the pump I have I would send it to you. Will dig for my notes first thing in the am. Rod
Old 04-06-2013, 12:30 AM   #7
Rock Hornbuckle
Rock Hornbuckle's Avatar
Holly makes a pressure regulator that is ajustable from 1-4 psi, I think the 94 requires a maximum 3.5 psi. You can google 'Holly 94' and get the exact pressure. Also google 6volt electric fuel pump, you'll get a plethora of choices. I believe the pressure reg comes preset at 2.7 psi.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 04-06-2013, 12:42 AM   #8
Rock Hornbuckle
Speedway part # 910-4259 6volt universal pos. or neg. ground 72 GPH fuel pump.
Semper Fidelis
Old 04-06-2013, 01:28 AM   #9
ctlikon0712
ctlikon0712's Avatar
Hey Rowdy, I conversed with Spence for a while and I looked through my notes as well. This was all he relayed to me about his setup, nothing about jet sizes.... Sorry
"To the right of the speedo is a switch to determine which gas tank I’m using. The cowl tank (10 gal) is the one with the gauge to tell how much gas is there, and is the “reserve” tank while Rallying cross country. Where you have that curtain box under the ass end of your Woody, I’ve installed an auxiliary 8 gallon gas tank, and feed fuel filters to a 3-way switch into a fuel pump into a pressure regulator into my Stromberg 97 Carburator. We would typically fill the cowl tank with known GOOD gas each night if necessary, then fill the Aux tank during the 3 scheduled stops between a 7:00AM to 7:00PM rally day."
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 04-06-2013, 05:51 AM   #10
ken ct
Start with 2# fuel pressure. omo ken ct.
Old 04-06-2013, 07:18 AM   #11
1931 flamingo
1931 flamingo's Avatar
Before you go to the trouble/expense of a f/pump, try running it gravity??
Paul in CT
Old 04-06-2013, 07:47 AM   #12
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I will tell you from experience on my own car, by using a 12v pump on a 6v system and you then don't need a regulator because the pump puts out ½ the rated pressure.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-06-2013, 08:23 AM   #13
john in illinois
john in illinois's Avatar
I use a Carter pump and a Holly 1-4 regulator for my 97. I run 2 lbs. These pumps have a long life and work well for a Model A.I set mine on the inside of the passenger side frame,hardly shows.
I got my pump from Arizona Model A's, but NAPA sells them too. Here is the pump from MAC's. http://macsautoparts.com/model-a-for...0H5P211000016/
John
john in illinois is offline   Reply With Quote
Old 04-06-2013, 12:13 PM   #14
Rowdy
I could not find the e-mail I was looking for. Thinking it may have been the victom of the fatal computer crash I had in 2009. Some stuff was savable and other parts were not. I did find a pic of the setup, but not enough for any detailed info from it. Rod
Old 04-18-2013, 09:02 PM   #15
youngrodder1929
youngrodder1929's Avatar
I ran 2 94s on my A just off gravity never had a problem 53 main jets
youngrodder1929 is offline   Reply With Quote
Old 04-18-2013, 09:43 PM   #16
garyaodell
I'm running a 94 on my coupe, most 94s came with a 54 jet for sea level use, I live a 4800ft and use a 52 with a 5 power valve. My engine is producing about 90 Hp and I'm getting 19 mpg on the hiway with a 3.78 rear end at 60 mph.
garyaodell is offline   Reply With Quote
Old 04-18-2013, 10:07 PM   #17
gwhite
gwhite's Avatar
I've heard horror stories about those regulators, seems like they always leak. My 'period' alternative is to pressurize the tank - 1922 Cadillac fuel pump and 1918 Dodge pressure gauge...no worry about voltage or leaks, just a pump every so often. (Disclaimer: my car is a T - RPU on an A chassis and the tank is in the bed)
gwhite is offline   Reply With Quote
Old 04-18-2013, 10:48 PM   #18
Art Bjornestad
Art Bjornestad's Avatar
I also use a 12 volt pump and on 6 volts it puts out just over 3psi.
Art Bjornestad is offline   Reply With Quote
