Old 04-05-2013, 05:27 PM   #1
farmerdick
farmerdick's Avatar
Default brake light switch
Hey Guys, I`ve got a good one for you!!! Rebuilt and refurbushed the entire brake system this winter TO THE LETTER using Les Andrews Vol 1 repair manual. The service brake rods and all four brakes are adjusted properly. Problem now, is the brake rod from the brake pedal doesn`t make contact with the brake switch plunger to turn off the brake lights. It worked before the overhaul but then again I hardly had any brakes and who knows how far off the service brake rods were. There is about a 3/16" gap between the plunger and the brake rod pad. If I adjust the brake peddle rod to make the plunger open the circuit the peddle isn`t even with the clutch peddle as their supposed to be. Whats going on?
Richard/Maine
farmerdick is offline   Reply With Quote
Old 04-05-2013, 06:05 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: brake light switch
Need more info. Float-a-motors? Arms put back on the cross-shaft correctly? What is the length of the brake rods now?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-05-2013, 07:35 PM   #3
Duffy1
What year model switch do you have ?
Duffy1 is offline   Reply With Quote
Old 04-05-2013, 11:27 PM   #4
partridgekelley
Take the rod off and add a little knob of weld to make it work. Just might be the lazy way! Gary
partridgekelley is offline   Reply With Quote
Old 04-06-2013, 05:21 AM   #5
farmerdick
farmerdick's Avatar
A year ago I rebuilt the entire front end including rear Float A Motor and had no problem with the switch not working. Not sure what the lengths of the rods are(are they measured from center of pin to center of pin?). The rods are straight as an arrow. The switch is an original 1930(July). Never took the arms off and the cross shaft can only go one way. I tagged the rods L or R when I took them off. All new rod pins. Thank you for any help on this situation.
Richard/Maine
Old 04-06-2013, 08:58 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
The problem is trying to set the brake rods to a specified length, this is just bad info whoever gave it. You first set up the service brake cross shaft. the service buletins call for a gap of 1/16 inch between the plunger on the brake pedal rod and the inside of the center crossmember, where the plunger meets the brake light switch , with the brake pedal at the top of its travel. The brake rods are adjusted so that the clevis pins will just enter the brake levers. One guy claims that some of the pedal rods have the plunger spaced wrong, this is possible.There are gyp parts out there. I only use brake parts from Snyders with good results.
Old 04-06-2013, 03:47 PM   #7
farmerdick
farmerdick's Avatar
Purdy, I completely redid the adjustments on the rods and was able to get the brake peddle rod to get the brake light switch to operate properly. Thanks to you and the others that helped me resolve this situation.
Richard/Maine
Old 04-06-2013, 04:34 PM   #8
Purdy Swoft
Thanks , Richard for the update. Glad it worked out!!
