#1 |
I've asked around and received both answers so once and for all, does a Murray Town Sedan's drip rails have a screw thru the tips to help hold them on? The car I'm working on has them and I don't think it's right. Thanks
DMAFC |
#2 |
I believe they were only installed originally by snap fit on the backing plate. Based on my experience with both Murray and Briggs 4 drs.I would say that if you are fortunate enough to have a car with the original drip rails, it is only because someone in the past placed a screw to hold a rail in place that was probably getting loose enough to be a problem. Seems like many owners in the past got tired of them coming loose and yanked them off the car and threw them in the weeds.
#3 |
My drip rails have screws that go into the header from the factory. Mine is a Briggs but they should both be the same in that regard.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
#4 |
My Murray has the screws at both ends. They look stock to me.
#5 |
Mine has screws, and original drip rails. No question screws were used. Oval head since the holes have a countersink in the rail.
#6 |
DMAFC |
#7 | |
![]() Quote:
If someone has a photo of a set without the holes on the ends, I'd be shocked. BUT, this is just an opinion...I'm certainly no expert, just the owner of a fairly unmolested 155A. |
