#1 |
The number stamped on a diamond Model A block is LB-----, with a star on the right side. Does this look familiar to anyone? The casting of the block has a few rough areas, namely below the water pump on the front of the block, behind the timing gear cover. upper front driver side. I don't know the history on this block. Bob
#2 |
Diamond block were sold after the Model A cars ended. Could have any number stamped by the person/company(s) that bought them.
#3 |
Thanks, when I saw the LB, Long Beach came to mind. Especially with the star on the end. The Head has Ford USA cast near Number 2 cylinder. Very little wear in the head on the stop for the water pump shaft. Thanks, Bob.
#4 |
I remember some posts on the old ford Barn a while back. Any way to access them. I would like to research the Diamond Blocks. Any leads, contacts, Information would help. How does one contact the ford archives? I will start another thread for this. Bob
#5 |
Here is a little info http://idisk.mac.com/forever4/Public...amondblock.htm
I have a diamond block that has no SN. It was a mule motor with an in and out box, stand alone unit. |
#6 |
RF = Richmond Ford (California) LB = Long Beach Ford (California) Ron |
#7 | |
![]() Quote:
#8 |
Dusty,
You are correct, it has the additional webbing to rienforce the rear crankshaft mounting. They were in effect a new Ford Engine. A member in our club picked one up here in Quincy; the only thing he did was counterbalance the crankshaft which was an A; it had a new B camshaft which we put in V blocks to check the lift, it had 331 lift on the intakes and 339 on the exhaust. We set the valve clearance at .014 on the intakes and .018 on the exhaust ; he also intalled a new 5.9 Brumfield head. What a strong engine !!!!! Ron |
#9 |
That's the info I am looking for. Thanks I have 3 diamond blocks now. I will look closely at the 2 I have had the longest. Thanks, Bob.
#10 | |
![]() Quote:
I have probably jinxed myself for this weekend as I am off with the local "A" club to Amish country in Ohio...I guess I should be lining up an engine rebuilder before I leave ![]() Warming her up in WV dusty |
#11 |
checked Plucks and Vince's sites and did not see any additional info on LB and RF numbered engines.....
Does anyone have any additional historical information on the California RF and LB serial number blocks? If I have it right. these diamond blocks were assembled with different parts than a replacement diamond engine. How were they distributed? I have one that came our of a 29 ford, said to be an original engine but the date stamping indicates it's a 1935 engine ????? is there any additional info I have missed? |
#12 |
Bob The archives from the old barn are gone forever as far as being in a useful condition. That is a long ways from what we were promised, but just the way it is. The search engine here only likes single words to search. Use the advanced search, type in diamond and look in the Model A Form. Looks like there is plently to look at. I will see if I can get the link to post below, but no gaurantees if it will. Rod
#13 |
#14 |
Guys I have a diamond block with the tag on rt. side "J306". It also has 2689012 on boss on drivers side stamped. What does this sound like it may be? A "Oct. 30 1936" engine? Does this have hardened seats in it does it have more webbing in the bottom end? What camshaft would it have had in it. Why is it stamped now with the 2689012.What do you know about what this engine may have been originally. The motor has a "B" head on it with 3 hole water pump.
#15 | |
![]() Quote:
#16 |
I have a 1935 diamond block with the engine pad stamped DMV******. It also has a welded up crack in the exact same spot as shown on Vince Falter's picture, from the pad through the water inlet.
#17 |
Any information on how many diamond blocks were produced?
Many have been a gaggle though, presumably many must have been reshaped into war machinery durring WWII. |
#18 |
I would think that the number stamped was added later. Bob
#19 |
The diamond is a foundry mark, also found on Columbia rear-end parts. I always thought it to be an independent foundry but have no proof of this.
