Old 03-18-2013, 04:48 PM   #1
Phil Noonon
Default Thomas head and Mallory distributor?
Hi, does anyone know if the Thomas head with a Mallory distributor, 2301105, requires the distributor cam shaft to be drilled and pinned to the oil pump? If this is a "dumb" question, bear with me as about everything is a learning experience for me.
Thanks!
Phil Noonon is offline   Reply With Quote
Old 03-18-2013, 06:48 PM   #2
hardtimes
hardtimes's Avatar
Default Re: Thomas head and Mallory distributor?
Thanks!
Hey Phil,
Dumb question..don't know, because can not figure it out !
Is this 'trick' question (s) ? First you could probably substitute any head and the question would be as confusing. Never have heard of a dist cam shaft attached to an oil pump 'drilled/pinned'. Usually, the dist/shaft has offset slots that must be matched up with dist and oil pump shafts.
Mabe 'new' setup,eh
hardtimes is offline   Reply With Quote
Old 03-18-2013, 07:20 PM   #3
Rock Hornbuckle
Rock Hornbuckle's Avatar
Hi Phil, If the mallory dist. is made for a Model A, it will have an offset slot in the bottom of its' upper shaft that will mate to top of your lower shaft.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 03-18-2013, 09:20 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Phil, maybe you're confused with the one piece dist shaft, which IS pinned to the dist? Otherwise, drop in the short shaft & just stick the dist in. Bill W. ( STICK means install!)
"THE ASSISTANT GURU OF STUFF"
Old 03-18-2013, 09:22 PM   #5
Phil Noonon
thanks guys, I now have a mental picture of how the distributor drives the oil pump.
Old 03-18-2013, 10:06 PM   #6
Bob C
This is what drives the distributor and oil pump.
Bob
