Old 01-14-2018, 10:02 PM   #1
1crosscut
1crosscut's Avatar
Default Frame spreader plans
A while back I found some plans for building a simple frame spreader basically out of square tube and angle. I'm sure that I printed it off but now can't find the print or the site I found it on. Any direction as to where to find it or plans to build one would be appreciated.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 01-15-2018, 06:51 AM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Frame spreader plans
Some alternates:
https://www.fordbarn.com/forum/showt...frame+spreader
https://www.fordbarn.com/forum/showthread.php?t=198353
Old 01-15-2018, 10:18 AM   #3
wrndln
Here you go. I made the frame spreader shown in the last three pictures using the dimensions shown in the first 6 pictures. It works very well.
Rusty Nelson
Old 01-15-2018, 12:51 PM   #4
1crosscut
1crosscut's Avatar
Perfect! Thanks
Old 01-15-2018, 09:49 PM   #5
Chris Haynes
Chris Haynes's Avatar
I used a '56 Chevy bumper jack.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-16-2018, 02:02 AM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Talking Re: Frame spreader plans
I’m sorry you contaminated your A!
Old 01-16-2018, 09:16 AM   #7
TerryO
TerryO's Avatar
TerryO
TerryO is offline   Reply With Quote
Old 01-16-2018, 09:25 AM   #8
Russ
Russ's Avatar
I found a quick, cheap, and easy solution at my local Home Depot. They sell post jacks in just the right size to fit between the Model A frame. This is the type of adjustable post that you see holding up the ceiling in old basements. I also used it to straighten my frame. It was between $20-$30. Most big box home improvement stores should have these.
Russ is offline   Reply With Quote
Old 01-16-2018, 08:36 PM   #9
Roger V
Roger V's Avatar
Here's my frame spreader with offset for the transmission clearance. It's 24 inches long, 6 inch legs (2 inch sq. tube, 1 inch plate). Frame plates are 3 5/8" x 4 1/2". Frame pads have 1/4" rubber. !/2" x 4" tap bolts one inch on center from bottom. Yes, I've installed many engines with greasing, prying, cussing, etc. but this eliminates that.
Roger V is offline   Reply With Quote
Old 01-17-2018, 10:07 AM   #10
JDupuis
JDupuis's Avatar
Nicely done Roger V. .
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
