Re: 8 ba not running
ok i figured it out the line coming from the fire wall had a fitting on it that i was using to attach the rubber hose to run to the fuel pump. this fitting is what is left over from the original fitting from the rubber hose that came with car. i am using a large hose fitting on pump for the 3/8 rubber hose. the fitting on fire wall was smaller which allowed air to come into rubber fuel line. i have a metal line from pump to carb coming in and rubber hose original type also coming in. this should take care of it.
thank you for all the help .
