Old 03-08-2012, 08:43 PM   #1
chiliman
Default Re: F150 tranny with overdrive
Jamie woops forgot to say I went with a open drive shaft a fellow in local club makes a nice set up so I still have the tail shaft and reqires to modify the f-100 cable thanks any way
chiliman is offline   Reply With Quote
Old 03-18-2012, 08:00 AM   #2
trctrdr
For anyone interested,,, Snyders has provided for me a floor mat for my 29 coupe that hasn't been trimmed, they special ordered it from the manufacturer. There are no holes cut and the outside edges haven't been trimmed.
I have my install complete, have been driving it for a couple of weeks and love it. The transmission along with a new Mel Gross steering box has made it into a different car.
trctrdr is offline   Reply With Quote
Old 03-18-2012, 10:45 AM   #3
AL in NY
AL in NY's Avatar
Thanks trctrdr, I have been trying to do this very thing but hadn't found a vendor (or manufacturer) that was willing to make a mat without the holes cut for the shifter tower and E-brake. I just sent a email to Snyder's asking for the same mat that you special ordered. Maybe they will make it a catalogue item.
AL in NY
AL in NY is offline   Reply With Quote
Old 03-18-2012, 12:20 PM   #4
Jamie86
trctrdr,
I just wanted to thank you for letting us know. We are getting ready to put a rebuilt motor and F150 transmission conversion in a 1930 Coupe asap. We need a new floor mat, so this is good to know.
Jamie86 is offline   Reply With Quote
Old 04-14-2012, 05:09 PM   #5
PetesPonies
PetesPonies's Avatar
Al, that's a great looking conversion as well.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 05-31-2012, 08:55 PM   #6
Duffy1
Steve ; You need to do some serious investigation as it relates to the gear ratio`s if you go with the f-150 . As posted earlier my 31 sw with b engine and f-150 trans likes to run 55-60 . When I go on a tour with my club they run about 45 . At that speed I am continually having to shift back and forth from 4th ( od ) to 3rd ,3rd to 4th when the slow down a little or we get into some hills.I also heard that f-150 trans are becoming harder and harder to find .I do like the synchronization .
Duffy1 is offline   Reply With Quote
Old 06-10-2012, 11:04 AM   #7
miss victoria
Duffy what gear set do you have?
miss victoria is offline   Reply With Quote
Old 06-10-2012, 07:52 PM   #8
AL in NY
AL in NY's Avatar
This best gearset for a Model A conversion is out of a 302-V8 powered 83-87 2WD Ford F150. See post #8 in this thread for a decoding chart. The ratios for that transmission are 3.25, 1.92, 1.00, 0.78(26.7% OD). Very close to the stock Model A transmission in gears 1st, 2nd and 3rd.
AL in NY
Old 06-10-2012, 10:24 AM   #9
PetesPonies
So how about a 3 speed truck trans?? Zillions of them out there. They are very short with a short tailhousing. Anyone used one or heard of it?? Sure no OD, but a nice synchronized trans.
Pete's Ponies
Old 07-26-2012, 01:50 AM   #10
roddyb34
roddyb34's Avatar
I am doing a 3 speed trans from a mustang etc,into our A with a jeep t150 shifter bolted to the top ,using the AA bellhousing and fabricated pedal mount ,its basicly the same set up as the F150 trans ,i have a steel plate made with the shoulder to mount the uni housing cup, i am yet to do the main shaft spline ,i would be happy with 3 gears with synchros no OD,will still have to shorten the torque tube and driveshaft a bit ,
roddyb34 is offline   Reply With Quote
Old 06-10-2012, 09:51 PM   #11
miss victoria
Thanks al im tired of beating an old horse!
Old 07-20-2012, 11:12 AM   #12
chiliman
what clutch disk is used in this application part number would sure help me out all that im finding they want to sell kit with presser plate one place wants 150 just for thedisk thanks for information
Old 07-20-2012, 12:40 PM   #13
Jim Parker Toronto
Jim Parker Toronto's Avatar
I am using one from a 1986 Ford T-bird 2.3L 4 cylinder turbo. 1 1/16" x 10 spline. Works great in mine! Got the whole setup, clutch, pressure plate, and throw out bearing, only throw the throw out away! Won't fit....
Jim Parker Toronto is offline   Reply With Quote
Old 07-25-2012, 08:11 PM   #14
Bassman/NZ
Bassman/NZ's Avatar
What does it take to bolt the torque tube cups to the back of the F150 trans? Is it an adapter plate?
Bassman/NZ is offline   Reply With Quote
Old 07-25-2012, 08:19 PM   #15
Bob C
Looks like this.
Old 07-25-2012, 08:31 PM   #16
Duffy1
Make sure you get the 23% od . not the 37 % or 41% .especially if you drive where there are hills.
Old 07-26-2012, 09:56 AM   #17
Duffy1
Will a 4 spd out of a V6 1989 ford ranger work .
Old 07-26-2012, 11:58 AM   #18
Jim Parker Toronto
Given the right amount of time and money, anything will work. We just try to do things that someone else has done before and done all the engineering. It makes it a lot easier!
Old 07-26-2012, 12:24 PM   #19
PetesPonies
I think all manual trans were 5 speeds by '89. Those transmissions have an integral bellhousing. That is not the trans you want.
Pete's Ponies
Old 07-26-2012, 12:31 PM   #20
CarlG
CarlG's Avatar
I would have never accomplished this if I had to do the engineering and fab work myself. But now that I have it installed, I couldn't be more pleased with the end result.
