#81 | |
[QUOTE=51 MERC-CT;653334]
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#82 | |
![]() Quote:
![]() ![]() ![]() ![]() Thanks again to 51 MERC-CT for tipping me off.
#83 | |
![]() Quote:
Yes, the instructions state that not running thermostats helps increase the flow, and to only run them in cold weather.
Thee Inland Emperors |
#84 | |
![]() Quote:
Wait, hold the phone. I thought in a previous post you mentioned that you called Skip and he told you not to use thermostats. I don't want to go back and re-read all the posts, but the thermostat thing is just coming to light now? Was this all done to stir up the pot? Last edited by Tim Ayers; 05-17-2013 at 02:51 PM. |
#85 | |
[QUOTE=Old Henry;653395]
#86 | |
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-17-2013 at 03:56 PM. |
#87 |
Using a fresh design he could design it for more flow, more pressure, whatever he wanted. The main difference is I'd expect the mixed flow to have less internal turbulence and less tendency to cavitate.
#88 | |
![]() Quote:
I did not run thermostats in my 33 or 34...never had an overheat. My 41 Ford I do have T-stats in, but I have a set of junky Bob Drake pumps on it...I am doing a new engine for it and I will get a set of Skips pumps. Not trying to promote, just saying they work, and work well.
#89 |
Rest assured that any promotion of Skip's pumps in the future that does not include the caveat about the thermostats is going to get a response from me regarding that problem. Nothing against Skip or his pumps, just in favor of full disclosure of all relevant facts.
#90 |
Henry, I have skips pumps on my 33 with the std engine,I made and fitted t/stats in the tops hoses,It sure made a difference in warming up and so far have been great.But I havent been out in it in summer yet,(thats 6 months away).
Also the pumps are the old ones rebuilt. If you want to fit the t/stats do what I did and buy a pair from the local auto shop,tig weld them on a small length of stainless exhaust tube then slip them into the top hoses. Hope you get your engine back soon, Lawrie |
#91 | |
![]() Quote:
#92 |
hunt them poor little quackers???...snifffff....what shot do you prefer??....use the old 12 gauge Ithaca pump with high brass....Mike
#93 |
I have posted maybe a 100 times about the use of modern thermostats in the hot summer causing the engine to run hot even with 8 .125 holes drilled in the flange to try to increase flow. Thermostats with small flow openings are like putting washers in the hose as recommended by lots of people for 60 or more years. The water was going out the over flow and the washers, the same as small thermostats slowed the flow, less flow eased up on the volume of water going into the top tank.
Less water into the top tank allowed less to flow out the over flow. This works in cooler weather but causes the engine to run hot in hot weather BECAUSE less water is flowing through the radiator. With the 4 lb pressure cap or 3 lb valve and either NO thermostats or Bob Shewmans full flow stats much more water is FORCED through the radiator. As I said a hundred times better cooling is achieved with more water in the system (filled up in the neck), more water flow by using pumps that deliver more water. Like the promotion or not there are NO PUMPS that come within 25 gallons in 5 minutes of what Skips pump produce. A shroud and a QUALITY 6 bladed fan also help. Make anyone of these improvements and you get some improvement, do all of them and it won't go over 180 at fast idle or road speeds in 100 degree temperatures. Henry I think you must be so engrossed in your ramblings that you don't read what others write or maybe you just don't understand. I would say it's both. G.M.
www.fordcollector.com |
#94 |
All of this talk got me thinking about rebuilding my entabulator. This link may help.
http://www.liveleak.com/view?i=3ba_1296857530 |
#95 |
Here is some hands on experience with Bob Drake's, Dennis Carpenter's, and Skip's pumps. I have installed them all on 1940 Fords I have bought and sold with Bob Shewman's large opening thermostats that install in the upper hoses near the radiator. I keep the thermostats in the cars year round. In the winter time there was no difference in the temperature of the cars under any circumstance. In the summer there was no difference in the temperature of the cars except in extreme conditions like on very hot days in traffic. In extreme conditions Skips pumps kept the temperature of the car at 180 while the other pumps would go up to 190 or as much as 200. When I would get back into a good traffic flow the other pumps would cool the car down to 180 within two miles. Bob Drake's pumps were $100 a pair on sale. I think Dennis Carpenter's pumps were $125. and I think Skips pumps were about $200. Bob puts his name on his pumps outer housing which I don't like. From memory I think Bob Shewman's thermostats were around $35 for the pair. I'm doing all these prices from memory and they could be wrong. One more thing if you need to talk to Skip or Bob Shewman you call them and talk to them. That is not the case with the other providers. I just wanted to shed some light from my flashlight on this water pump issue. There is no correct answer for all the circumstances that could exist with each individuals needs.
#96 |
G.M. I dare you, no, double dare you, no, let's make it double DOG dare you to post the reference to one post of yours that has ever said that Skip's pumps should not be used with any stock thermostats in 32-48 cars. I have a pretty good memory and don't remember any and just spent some time searching and didn't find any.
#97 |
I think you must be losing your memory I posted it so many times I'm getting tired of typing it trying to get it to sink in to people like you. G.M.
#98 |
In searching for any warning by G.M. that Skip's pumps should not be used with stock thermostats in any 32-48 cars I found this image from a post of his in August 2010 that shows skips impeller quite well. That and Tim Ayers' pictures is all I was asking for when I started this thread. Sure was hard to get.
#99 |
This thread has gone epic....
Let me shift gears and get us to a happier place: 1.5 or 1.6 valves? Discuss... |
#100 |
Amen to that. And all I asked for was a picture of something, no opinions, no judgements, no criticisms, no testimonials, no advice, no arguing, no bickering, just a picture. Geeezzz.
