#41 | |
![]() Quote:
I've bought used cars that smoked and burned a lot of oil that people gave up on trying to repair....spent $8 on a quart of MMO and all problems were solved. And I have about 5 more stories if you want to hear them.... |
#42 |
It always helped keep the valves from sticking in my old(pre-1958) Model L Gravelys...
I add 2-4 ozs MMO to each tankful in my carbureted vehicles. I have also used it to free-up stuck engines. |
#43 |
over 30,000 mi on the roadster, always used mmo in the gas, still has great compression .
#44 |
txturbo, I guess you don't understand the smiley face remark.
Actually, I'm not a MMO user. I use Sea-foam. |
#45 |
I've not used Sea Foam but a highly respected mechanic that I know told me to pour some MMO in my 31 Buick to cure a sticky valve. I used it and it worked so now my Model A gets some and my 66 Lemans will be getting some.
#46 |
#47 |
Does anyone have an issue with 4 oz per 10 Gal. of MMO added also with a proper amount of Sta-Bil. I believe 1oz per 5gal?
#48 |
I use 110 octane low-lead gas.. I wouldnt put MMO in my lawnmower.
#49 |
#50 | |
![]() Quote:
![]() Sea Foam is also good for the gas to set over winter. |
#51 |
#52 |
#53 |
#54 |
#55 |
#56 | |
![]() Quote:
Just had lunch with a buddy that just bought an 81 El Camino that has been in storage for 2 years. It has 2 valves sticking and he was telling me he was going to pull the heads today.I told him to try the MMO trick. Will see what happens later today. |
#57 | |
![]() Quote:
#58 |
"""quote---- txturbo
Just had lunch with a buddy that just bought an 81 El Camino that has been in storage for 2 years. It has 2 valves sticking and he was telling me he was going to pull the heads today.I told him to try the MMO trick. Will see what happens later today.quote"""" If it sat two years drain and put fresh ethanol ![]() Last edited by Mitch//pa; 02-10-2013 at 11:37 AM. |
#59 |
Yep, what Tom and Mitch said.
#60 |
the fuel and carb are fine....its the valves that are sticking.
