Marvel Mystery Oil How many Fordbarners use Marvel Mystery Oil in your gasoline or in the oil? It has done wonders for my cars.
Re: Marvel Mystery Oil tom here is a recent 94 post thread about who uses it etc..you can do a search for alot of information thats been discussed
http://fordbarn.com/forum/showthread...el+mystery+oil |
Re: Marvel Mystery Oil I use 4 oz at every fill up.
Re: Marvel Mystery Oil Quote:
Re: Marvel Mystery Oil I also use it every time...........
Re: Marvel Mystery Oil I use it in all my shop in-line air tool oilers.
Re: Marvel Mystery Oil 4 oz every fillup plus some in the oil. Thanks to the Ford Barn for educating me about it. Also use it in the A's tow vehicle ('97 F250) and it made a huge difference - it was a marvel - ous difference. Why ? I have not idea but it worked wonders.
Re: Marvel Mystery Oil Every time I gas up. The fellow who rebuilt my engine told me it it is "top oil" and keeps the valves from hanging up. It offsets the unleaded gasoline.
Re: Marvel Mystery Oil I use it for every fill up as well. Have not tried it in the oil but I do add a dash each am to my coffee. Seems to make me step smoother !
Re: Marvel Mystery Oil I'm trying it in my A now. Add some at fill up just as preventitive medicine. We'll see if it does anything.
Re: Marvel Mystery Oil I use it more as a preventative measure.
Re: Marvel Mystery Oil :)I carry a 4 oz. bottle of the oil for every fill-up, works good for the old Phaeton.....
Jim |
Re: Marvel Mystery Oil I had a little valve sticking in a 31 Buick and it totally cleared that up. A great upper cylinder treatment when used in the gas. I can't remember if I've used it in the oil.
Re: Marvel Mystery Oil I use it every oil change
Re: Marvel Mystery Oil My friend told me that if you have valve seats that are ground on the wider side, the unburnt Mystery Oil collects on them, causing carbon to stick. Thus, poorly sealing valves and eventually other problems. Not sure if there is any merit to his theory. Thoughts?
I've found that at modern highway speeds the babbitt pounds out long before the top cylinders wear out, so what's the use? Nobody around here seems to want to repour an engine without boring the cylinders out and doing the whole thing over. Personally, I did have a sticky valve issue and a one-time dose of MMO seemed to help that. |
Re: Marvel Mystery Oil Re: Wonders and Marvel...
In the A, it's use has smoothed out a rough idle; and, the engine does not backfire as we slow down at speed for a red light (that expression "at speed" is used loosely). You wont find any hills in our part of South Florida so can't speak for a decent on a steep hill. For the '97 F250 at 200,000 + miles, there has been a sharp improvement in acceleration. The truck was driving tired and as I wanted to use it for the Blue Ridge Tour,the Marvel was added. Put off getting a replacement truck any time soon. |
